stuck in 5th - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 06-12-2012, 11:28 AM Thread Starter
stuck in 5th
i have a 2003 f350 6.0 w/tourque shift tranny just rebuilt after insallation the truck shifted fine for 4 miles when i took it on the interstateat 65 mph the tranny seemed to jump out of gear when this happened the seedo went to zero. i pulled off and shut the truck down when i tried to start it back up there was nothing will not start with the key jumped the starter to get it home and the tranny is stuck in 5th gear and speedo is not working od light flashing its at the tranny shop there is all kinds of codes but nothing that is pointing to the tranny any ideas
george german is offline
post #2 of 2 (permalink) Old 06-13-2012, 12:54 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: stuck in 5th
It's an electrical problem. A harness is unplugged, or cut, or a ground is bad.
Mark
Mark Kovalsky is offline
