2000 4r100 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-09-2012, 04:47 PM Thread Starter
IHPowerstroke7.3's Avatar
2000 4r100
So on the way home from training last night, trans seamed to have a bit of "trailer hitch" feeling going on. Stopped for fuel, put it in drive to pull away from the pump and.. a delayed, slipping basically no foward engagement. Trans has 200 000 km on it, previous owner (co worker) said that this was happening to him after towing up to temp and same thing. So I have a feeling I have a fwd clutch leak, getting old and tired i guess. Time for an overhaul.
Anyways I am a ford tech, I can assemble transmissions to ford specs but I'm no "builder". I'm just wondering what everyone on here would recommend for upgrades for a DD truck. I do tow fairly often and usually when I do it is 5000 lbs or more. I want to upgrade to a multiple disk converter (seams common) who makes a decent converter for a decent price? I've read I can swap in a 5r110 converter but haven't figured out if it is a direct swap or what is needed. I don't plan on making huge hp numbers but I do want a strong trans. What other things should I upgrade?
IHPowerstroke7.3 is offline
post #2 of 5 (permalink) Old 06-11-2012, 03:07 PM
cjsobas
cjsobas's Avatar
Re: 2000 4r100
what i did to build mine is triple disk converter from racer x, red egale clutchs and steeles from racer x and a bts valve body an a 6.0 cooler. 20000 and still counting runs great and heat stays at a minuim even towing heavy loads
2000 F350 7.3l custom 5in exhaust, glowshift pillar gauges, 4in sky jacker lift, edge evo only on tow built tranny/ bts valve body/alto clutches and steeles/racer x triple disk torque converter, 20in moto metel 955, 35/12.50r20 nitto m/t, ww, 2ton helper springs
cjsobas is offline
post #3 of 5 (permalink) Old 06-12-2012, 12:20 AM Thread Starter
Re: 2000 4r100
I scored a used 6.0 cooler last week at work, plan to flush and install it. How do you like the racer x converter? Did you change stall at all? How do your shifts feel with the BTS valvebody?
post #4 of 5 (permalink) Old 06-12-2012, 12:53 AM
cjsobas
cjsobas's Avatar
Re: 2000 4r100
Idk about the stall. But I got the compoition converter I love it.and the bts didn't change much just driving but when towing it makes a world of diffrence
cjsobas is offline
post #5 of 5 (permalink) Old 06-12-2012, 10:15 PM Thread Starter
Re: 2000 4r100
Sounds good, thanks for the info.
