Changed ICP now trans shifts different. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 06-08-2012, 01:57 AM Thread Starter
I changed the icp sensor today and now my engine runs fine. But now that the cel light is off, the trans doesn't shift as firm as before. Instead of a hard, solid shift, now it seems to "slide" when it shifts. It's not slipping, it just doesn't shift firm. Is there anything simple I can do to get that solid shift back? It's an E4OD in a '95 F-350 cab and chassis with a 3 yard dump. Thanks.
msscatter is offline
post #2 of 2 (permalink) Old 06-13-2012, 12:46 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: Changed ICP now trans shifts different.
Scan it and see if it has any codes, then clear all the codes and clear the KAM.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
