4R100 transmission line pressure specs? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 06-04-2012, 05:51 PM Thread Starter
heep70's Avatar
Can anyone tell me what the line pressure specs are for a 4R100 transmission? Or point me in the right direction to find this info? Thanks
Greg
2000 PSD F250 4X4 Crew, John Wood 4R100, DP Tuner, 4" Diamond eye, Tymar, LIFT, 35" Toyos, Pillar gauges, TC lockup switch, 6.0L cooler, Single core rad, Most of all a Cool Driver, THATS ALL.
heep70 is offline
post #2 of 6 (permalink) Old 06-04-2012, 06:41 PM
zilla68's Avatar
Re: 4R100 transmission line pressure specs?
what I found was
park/neutral 50-65psi
drive 50-65 psi
reverse 85-110 psi
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #3 of 6 (permalink) Old 06-04-2012, 08:21 PM Thread Starter
heep70's Avatar
You found this in a book or testing of your own? Thanks
Greg
heep70 is offline
post #4 of 6 (permalink) Old 06-05-2012, 02:38 AM
zilla68's Avatar
I just googled 4r100 line pressure and it came up in a set of instructions.
Chris
Moore, Oklahoma
6637 tymar
3:55 gears
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #5 of 6 (permalink) Old 06-12-2012, 03:04 AM
Need a ride.
Strokerstooge's Avatar
Kinda makes sence since under load our tranny's puke under a bit more line pressure in reverse.
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
Strokerstooge is offline
post #6 of 6 (permalink) Old 06-19-2012, 03:50 AM
According to ATSG the 4R100's line pressures=
P,N 50 to 60psi at idle
R 70-100psi
OD, M2 50-65psi
M1, 70-115psi
and the pressure jumps from175 and all the way to 240psi at stall.
Hopefully soon i can afford to overhaul my tranny because it took a giant #### on me. I'll post the build when finished, but it's gonna take a while?
leroynasty is offline
