vacuume lines on top of 4R100 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 05-16-2012, 11:08 AM Thread Starter
Unhappy vacuume lines on top of 4R100
I got some help removing the 7.3 from my Excursion and a vacuume line that sits on the top of the transmission pulled loose. Long story short i did not see when or where it was pulled from and cant find/see where it hooked to. The motor and turbo was reinstalled before remembering the hose....Any one have a trans out that has vacume lines connected or be able to tell me where the line connects. It is a soft hose no clamp and not broken it is connected to the transfer case on the drivers side for the other end.
a68camaro is offline
post #2 of 2 (permalink) Old 05-16-2012, 12:56 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: vacuume lines on top of 4R100
It isn't a vacuum line, it's a vent line. There is a clip on the dash panel that holds it up.
Mark
Mark Kovalsky is offline
