2005 6.0 F350 Transmission - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-08-2012, 05:07 PM Thread Starter
Location: Live now in the San Francisco Bay Area. Santa Clara to be specific.
Hi All.
I have just started hearing and feeling some stuff that i can only assume is Tranny. I have 103,000 mile son it and have had no issues to date. Basically, last week it happened for the first time and has happened a few times since (very sporadic, and not consistant at all). Basically, it pretty much always happens at slow speeds often when decelerating. It will sound like i picked up a tree branch and am dragging it (around 20-30 mph). Then when I slow down to a turning speed on a surface street (~~10 mph) the the scraping noise will increase to a "hiss" and then i will feel what i can only assume is the tranny fall back into gear.
ANY HELP or comments are greatly appreciated. Not a mechanic myself. But a bunch of my buddys and cousin are. Im just trying to get some infor on this issue before I blow my life saving on a new tranny.
Thanks,
Tony.
TonyDriver is offline
post #2 of 5 (permalink) Old 05-08-2012, 09:14 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 2005 6.0 F350 Transmission
After you blow your life savings on the transmission spend a few bucks and change the u=joints in the driveshaft. That will fix this problem.
Mark
Mark Kovalsky is offline
post #3 of 5 (permalink) Old 10-21-2013, 03:29 PM Thread Starter
Thanks Mark, I actually did this last year and it fixed it. Didnt spend a penny on the tranny. so for that.. thanks.
Now with the new year i just got the Death Wobble. Started yesterday... any advice on that?
Thanks,
Tony
post #4 of 5 (permalink) Old 10-22-2013, 02:01 AM
Not from me. The transmission isn't causing this and that's where my expertise lies.
Mark
post #5 of 5 (permalink) Old 10-22-2013, 04:53 PM
zilla68's Avatar
check the track bar,
are tires balanced?
leave the truck off, have someone sit in the drivers seat with key on engine off, you get under the front end and have them turn the wheel back and forth, this will show you where the slop is.
On my jeep it was the track bar was worn, but until I did this test, I couldn't see it, but my 10 year old turned the wheel with the engine off the best he could, and it stuck out like a sore thumb.
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
