School me on the 4r100 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 05-06-2012, 02:02 AM Thread Starter
Buford-61's Avatar
Long story short, my trans has a busted case. A BTS is on my wish list, but aint gonna happen anytime soon.
What I need to know, what are the differences between a gas & diesel 4r100?
Will a V-10 trans hold up behind a 7.3?
Will the cases interchange (gas/diesel)? (Would I be able to put the guts from my existing trans into a 5.4 case?)
What year range can I use, anything from 99-04 would be ok? I have seen some listed on e-vil-bay, but they only list 01-04 trucks.
It's my understanding that a 4x2 trans can be converted to a 4x4 trans by changing out the output shaft and tailhousing. Is this correct?
i don't do any towing or heavy hauling, and my rig is basically stock, so I don't need bulletproof at this point. I just want to get it back on the road and get by for a year or two while I save up for a BTS.
Any other input would also be appreciated.
2000 F-250 SCLB 4x4
Ex console
Headache Rack
Husky tool box
Rhino lined
SpynTec Hub lockers
DieselSite Coolant Filter
DieselDite Trans. Filter
203* thermostat
AIH delete plug
BTS
Diamond Eye 4" Exh.
4 gauge a-pillar (Trans. Temp, Fuel Pres., EGT, Boost)
S&B intake
PHP Hydra
38r w/ww2 (Pending install)
Wish list - too #### long!
Buford-61 is offline
post #2 of 4 (permalink) Old 05-06-2012, 09:02 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: School me on the 4r100
In theory it should, but we will never know because a V10 trans won't bolt to a 7.3L
Ye, you can put you guts into a 5.4L case. It would make a strong trans for a 5.4L or 6.8L, but won't bolt to a 7.3L.
Diesel 4R100s were made from '99 to '03. In '04 the only 4R100s made were for gas engines.
That is correct. All you need to do to change the output shaft is to take EVERYTHING out of the trans, install the 4x4 output shaft, and rebuild the transmission.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #3 of 4 (permalink) Old 05-06-2012, 04:33 PM
econolaw
olyaee's Avatar
I like having you here Mark, you're information is always appreciated.
2001 E-350 15 pass
olyaee is offline
post #4 of 4 (permalink) Old 05-06-2012, 05:15 PM Thread Starter
Buford-61's Avatar
Good to know. Thanks.
I had been under the impression that they (the gas trans.) would bolt up to the 7.3, they would just be a grenade waiting to blow at the first blip of the throttle.
2000 F-250 SCLB 4x4
Ex console
Headache Rack
Husky tool box
Rhino lined
SpynTec Hub lockers
203* thermostat
AIH delete plug
BTS
Diamond Eye 4" Exh.
S&B intake
PHP Hydra
