Grinding in reverse - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-28-2012, 10:11 PM Thread Starter
PSD
CNDiesel's Avatar
Grinding in reverse
When I put my 1996 in reverse and give it lets say more then 1/4 throttle to go backwards, the trans starts to make a grinding noise. Any lesser throttle it seems fine. I have to baby the throttle in reverse so it doesnt make that horrible grinding noise.
The truck got a "rebuilt" but previously used trans installed right before I bought the truck. (only put 4500mi on it sence i bought it)
Now theres been so much $*#% poorly assembled and loose on this truck that i am questioning if the torque converted was seated and clicked in when installed... wouldnt suprise me now.
But if that were the case wouldnt the TC leak ATF? Or if some how something went wrong during the installation process???? I didnt install the trans or was there so I dont know.
I checked to see if the TC was bolted to the flex plate and yes all 6 nuts are tight.
Any ideas on what could be the problem? internal? t-case? tq converter?
1996 crew cab long box. 3.73s, auto 493/1135 stockish auto trans.
CNDiesel is offline
post #2 of 3 (permalink) Old 04-29-2012, 02:27 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Grinding in reverse
It is probably something on the engine or transmission hitting the body in reverse.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #3 of 3 (permalink) Old 11-20-2012, 12:27 AM Thread Starter
PSD
CNDiesel's Avatar
turned out to be broken springs in the valve body.
CNDiesel is offline
