6.0 torque converter problems? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-27-2012, 01:44 AM Thread Starter
bwstone92's Avatar
When my tranny is not at operating temperature and the torque converter locks in 5th gear around 50 mph the truck starts to vibrate real bad if i get on the gas.
I thought it was maybe the death wobble but it doesn't make sense because it dosn't happen when the tranny is warm and it isn't cause by bumps in the road or anything, just if i try to accelerate with it locked.
i don't have any codes.
Any ideas?
04 Harley Davidson F-350 6.0
-05 Harley makeover
2010 Harley Davidson F-350 6.4
bwstone92 is offline
post #2 of 9 (permalink) Old 04-27-2012, 02:01 AM
Re: 6.0 torque converter problems?
Check the fluid level.
range91 is offline
post #3 of 9 (permalink) Old 04-27-2012, 11:06 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
My idea is that you have a misfire when cold.
Mark
Mark Kovalsky is offline
post #4 of 9 (permalink) Old 04-27-2012, 04:47 PM Thread Starter
bwstone92's Avatar
tranny fluid is full
what would a misfire come from?
that makes sense i guess because the torque converter locking is putting extra load on the engine?
-05 Harley makeover
post #5 of 9 (permalink) Old 04-28-2012, 03:07 AM
The misfire comes from a bad injector most of the time. Misfires are easiest to detect in overdrive with the converter locked. They really stand out with the high load.
Mark
post #6 of 9 (permalink) Old 05-01-2012, 01:44 AM Thread Starter
bwstone92's Avatar
well i changed the oil this weekend and the problem seemed to go away a bit, it is still noticeable but not nearly as bad, i guess im gonna need some injectors soon
-05 Harley makeover
post #7 of 9 (permalink) Old 05-01-2012, 02:06 AM
Certified Engine Destroye
treetechsixOH's Avatar
I say sticky/failed injectors or a bad FICM. I'm calling it now. : )
___________________________________
03 CCSB Lariat 350 SRW
Built by me @ Outlaw Diesel Performance
Warren/K&N/Deleted/Exhaust, few other goodies.
Studs, SCT, Nitrous Express, ODP RR, Custom Fuel waiting for install.
treetechsixOH is offline
post #8 of 9 (permalink) Old 05-01-2012, 10:50 AM
Try revx before replacing the injectors has fixed a lot of guys issues worth a try Imo.
range91 is offline
post #9 of 9 (permalink) Old 06-12-2015, 01:03 AM
my transmission has a slight shake,shimmy when starting from a stop
nickbloom is offline
