TC lock up pressures inside tranny??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 09-05-2007, 09:34 PM Thread Starter
<<< THE GAUGE WHORE...
CSIPSD's Avatar
What are the highest pressures you might see at the pressure port? Need to get a sender for the Drive Oil Pressure and not sure if a 0-300 or 0-400 will work.
Joe
CSIPSD is offline
post #2 of 5 (permalink) Old 09-05-2007, 11:08 PM
Caption This
444-4D's Avatar
Re: TC lock up pressures inside tranny???
If you are going to continuously monitor the pressure, I think you are going to be in the 70-170 range.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #3 of 5 (permalink) Old 09-06-2007, 12:15 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
You asked two different questions, whether you know it or not. The title asks for TC lockup pressures. That's going to be in the 120 PSI range. Measuring it will be a real trick. You need to remove the trans, disassemble it, and plumb in some high dollar transducers to be able to read it.
Then you ask about putting a sender in the pressure port. That isn't lockup pressure, it's line pressure. Line pressure can get to about 330 PSI in reverse at stall speed.
Mark Kovalsky is offline
post #4 of 5 (permalink) Old 09-06-2007, 01:16 AM Thread Starter
CSIPSD's Avatar
Thats what I am trying to watch, so you will see as much as 330-350? Thats what I was thinking to begin with, so my 0-400 psi gauge is right.
Joe
CSIPSD is offline
post #5 of 5 (permalink) Old 09-06-2007, 01:30 AM
X Racer
Racer X's Avatar
At stall speed in reverse you may see that pressure. Thats done holding the brake and reving the engine to stall RPM in reverse. Most Tranny diagnostics use the 0-400 gauge. That's Ford spec gauge for pressure testing the 4R100 and E4OD.
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
