Zf5-42 reverse stop plate? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-19-2012, 11:33 AM Thread Starter
diesellaxer's Avatar
Not sure if this is the correct term for it but what is the plate that goes on the bottom of the shifter called? It holds reverse in and makes it so you can't put it in reverse on the fly I suppose!
Trying to sell the truck but can't seem to figure out the name to tell the guy!
diesellaxer is offline
post #2 of 2 (permalink) Old 04-19-2012, 11:30 PM
Re: Zf5-42 reverse stop plate?
Note totally sure but I call it a Reverse Lockout Gate, if we are speaking the same thing here. The Reverse Lockout Gate prevents shifting into reverse while driving in a forward direction gear. Moreover, it specifically prevents a shift from 5th directly into reverse (5th to 4th downshift) or 3rd to Reverse rather than 4th upshift.
Short throw shifter mod?
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
