Trans temp - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-17-2012, 04:15 PM Thread Starter
morseranch's Avatar
Trans temp
This is probably a stupid question but it really has my curiosity up. I have an 05 F-250 and when I fire her up in the morning it takes the normal amount of time (5-10 min depending on outside temp) for the engine to warm up, the trans however reaches normal operating temp in only a couple of minutes. Just doesnt make sense to me. Why so fast on the trans temp? Is this normal or should I be looking for a problem? Did a flush and filter change recently and everything looks and smells and operates fine.
Mark
05 F-250 Lariat
6" lift W/ 35's
Stock W/ Sinister coolant filter system, BPD 6 phase FICM, blue spring upgrade
51 gal Titan fuel tank
Edge Insight CS
morseranch is offline
post #2 of 6 (permalink) Old 04-17-2012, 06:20 PM
me2
Re: Trans temp
That is the way the temps work on my 08.
When the engine is idling the TC is creating heat and thus the transmission warms up faster than the engine. The engine has more liquid and mass to get warm.
New truck.
08 F350 King Ranch
Long box CC 4x4
6.4 5R110
Soon to get a Cummins 6.7 transplant.
Old truck.
Red '99 2WD F250 CC SWB
3rd gen 325/610 Cummins, ZF6
Custom air ride suspension
me2 is offline
post #3 of 6 (permalink) Old 04-18-2012, 04:04 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Trans temp
That's completely incorrect. Not even close!
The engine warms up faster than the transmission. Stuff is burning in the engine. That creates heat! Nothing should be burning in the transmission.
When the engine is warming up (that's a waste, but I digress) in park or neutral the torque converter is producing essentially ZERO heat. There is almost no slip, and there is no load, so there is no heat.
The transmission doesn't warm up faster than the engine. The people that engineered the factory gauges decided that the transmission temperature should read right in the middle of normal when the transmission has reached the very hot temperature of 50F. The engine has to get a lot hotter than that to reach the middle of normal.
Mark
The good thing about science is that it's true whether or not you believe in it. ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #4 of 6 (permalink) Old 04-18-2012, 03:19 PM Thread Starter
morseranch's Avatar
Re: Trans temp
Thanks for the input, I plan on getting some gauges soon so I can get a more accurate reading on the trans. Still wondering why they engineered the gauges that way though. My trans gauge never gets above the middle of the normal range and I know my trans gets hotter than 50 degrees.
Mark
05 F-250 Lariat
6" lift W/ 35's
Edge Insight CS
post #5 of 6 (permalink) Old 04-18-2012, 05:17 PM
Re: Trans temp
Yea gotta love those ford engineers
range91 is offline
post #6 of 6 (permalink) Old 04-18-2012, 09:09 PM
Re: Trans temp
If your gauge goes to the yellow then you are at 230F. Red is 260F. Contrary to popular opinion reaching these temperatures does NOT mean your trans is toast.
Mark
