6.0 Tranny Cooler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-15-2012, 04:24 PM Thread Starter
6.0 Tranny Cooler
I have yet to find any info on adding a second cooler for the 6.0. Just curious if anyone would see any issues with this? Only reason is for added protection when towing on hot days. There seems to be enough room in front of the radiator to add another cooler in line with the stock.
Built by Tri County Diesel
06 F250 CC SB Lariat FX4
ARP Head Studs
AFE Stage 1 Intake
Upgraded FPR (Blue Spring)
6.4 Banjo Fuel Bolts
Sinister EGR Delete
SCT (tuned by Vivian, Looney Wild)
Edge CTS
Sinister Coolant Filter
PowerMax Turbo
Zoo Dad Mod
IDP FICM Tuned
justin99 is offline
post #2 of 2 (permalink) Old 04-15-2012, 04:33 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 6.0 Tranny Cooler
I see issues with it. The trans cooling in your truck is so good you don't need to add a third cooler. It will cause more restriction and little, if any, additional cooling. Don't do it.
I've towed at max GCVWR up an 8% grade at +110F ambient temperature and could only get the trans up to 200F.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
