Any experience with ford reman HD4r100 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-12-2012, 05:08 PM Thread Starter
Looks like truck needs a trans does anyone have experience with ford reman hd4r100. I know about BTS trans called this morning and he is a month out mid may. I need something sooner than that. I use this truck very little only to tow my camper most years it only sees 6000-7000 miles. Truck is already 12 years old not sure on how much longer I will keep it. So what kind of luck have you had with ford reman HD.
Duanesz is offline
post #2 of 6 (permalink) Old 04-12-2012, 05:16 PM
Nose picker
Re: Any experience with ford reman HD4r100
My dad has one in his truck. It's been good and no problems. Give John Wood a call and see what his wait time is. He has a few options you could do. Bring the truck in, drive another vehicle to his shop and exchange transmissions, or he can ship you one. I have his tow master and it's a really nice unit. Shifts smooth but firm. No banging into gears.
02 F250 cc/sb 7.3 2wd 4R100
Denver is offline
post #3 of 6 (permalink) Old 04-12-2012, 08:01 PM
bracketracer's Avatar
I helped my brother-in-law put one in his '99 F350 back in June of 2008. Has held up fine there. He said he thought it pulled better than the stock trans did with a Banks trans command on it (He took the Banks unit off before we put in the HD4R100).
Stephen
edit: We did add the 6.0L trans cooler at the same time. I'm sure that had to help.
Newest project: 1995 F350 CC/DRW 2WD E4OD. 3" DP, 4" Diamond Eye system. But I'm still fixin' the broken stuff......
bracketracer is offline
post #4 of 6 (permalink) Old 04-13-2012, 06:29 AM Thread Starter
Stephen
How long did the install take? I am going to the local trans shop today to have the codes pulled. Guy at trans shop said just od light is flashing dont mean the trans is toast might be a shift solenoid he said. Well I hope its something minor I dont want to dump a bunch of money in this truck right now.
Duanesz is offline
post #5 of 6 (permalink) Old 04-13-2012, 08:32 PM Thread Starter
Guess I jumped the gun. Trans guy said code was for slip in 2-3 shift. He asked was truck cold I said yes. He cleared code and said drive it and see if it comes back.
Duanesz is offline
post #6 of 6 (permalink) Old 04-13-2012, 10:38 PM
We did the trans and the cooler over a weekend. We didn't rush, I'm sure it could be done in a single day. I welded up an adapter to fit my floor jack to help with the install, that took a couple of hours.
