4R100 stuck in high - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-06-2012, 12:45 PM Thread Starter
4R100 stuck in high
Looking for advice here as to what is failing on my transmission.
My symptoms happen only when the truck is cold.
I get in the truck, put it in drive to take off and it is in what seems to be 3rd gear. I can pull the shifter into 2nd gear then i notice the down shift and it accelerates a little easier.
After I drive around town a while long enough for the truck to get to normal operating temperature then I can put it in drive and all is back to normal.
If I get out on the high way before its up to normal then the o/d light flashes. I ran the codes the transmission has a turbine input sensor malfunction.
If I am on the high way the light is flashing it wont go into overdrive and the torque converter wont lock in. Once I am up to normal operating temp i can turn off the ignition for a few seconds (with the truck in neutral) then start it back up put it in drive and all is normal again.
Does this sound like a sensor or something electronic?
I pulled both the front sensor and the rear sensor and they checked in the normal range ohms.
oil is full.
turbobobby is offline
post #2 of 4 (permalink) Old 04-06-2012, 01:21 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 4R100 stuck in high
The code doesn't mean the sensor is bad. It means the computer doesn't see an input from the sensor. If the sensor is fine then the problem is almost always in the wiring to the sensor.
Even so, that should not cause your problem. It sounds like the solenoids are not powered. The 4R100 defaults to fourth gear when there is no power to the solenoids.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #3 of 4 (permalink) Old 04-06-2012, 04:31 PM
PHPDiesel's Avatar
Ding! Ding! Ding! We have a winner!
Cody
PHPDiesel is offline
post #4 of 4 (permalink) Old 04-06-2012, 06:34 PM Thread Starter
where can i see some detailed information about the electronic components of this transmission?
i would like to see what all is electric and when its applied, triggered, or activated.
i need to trouble shoot this thing myself. the repair shops around here just rip off people.
i appreciate any information you all can provide!
