Transmission temps - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 33 (permalink) Old 04-02-2012, 06:59 PM Thread Starter
techteacher's Avatar
Transmission temps
What is to hot for a tranny? Pulling my Skid loader the other day mine got to 260 and I was on a little two lane back road and couldn't pull over. I bought a 6.0 cooler that hasn't arrived yet but what usually causes it to heat up that bad. I was probably pulling around 14,000 pounds with the loader and trailer plus I am running the semi conversion so tire measure around 36" it's an e99 dually. Do you think it's ok how bad will high temps hurt it?
techteacher is offline
post #2 of 33 (permalink) Old 04-02-2012, 07:24 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Transmission temps
Running that high is not good for it. What causes it is a heavy load causing the torque converter unlocked. Your oversize tires with stock gearing and big load is causing a HUGE load on the torque converter. A 6.0L cooler will help, but if you are going to keep towing this load you need to change the axle ratio.
You're early '99 probably doesn't have a cooler in the radiator. A radiator with a cooler will help a lot, too.
Mark
Mark Kovalsky is offline
post #3 of 33 (permalink) Old 04-03-2012, 01:04 AM Thread Starter
Changed back to stock bit it's still heating up quick in a 5 mile trip it was up to 210
post #4 of 33 (permalink) Old 04-03-2012, 01:21 AM
If the trans cooler is restricted the cooler bypass will open and little if any fluid will go to the cooler. It's also possible that the spring in the bypass has fatigued and isn't holding the bypass closed when it should.
Mark
post #5 of 33 (permalink) Old 05-03-2012, 07:08 PM Thread Starter
I changed back to stock but it is still heating up really bad even on the highway empty its getting up to 180* I had a load of rock in the bed on the scale I was at 14,200# and by the time I got to my house 7-8 stop lights it was up to 230* I don't think that's right any idea why that may be? It doesn't feel like the tranny is slipping or anything it still seems to pull great it's just getting hot.
post #6 of 33 (permalink) Old 05-03-2012, 08:04 PM
Did you read this?
Or maybe this?
Mark
post #7 of 33 (permalink) Old 05-03-2012, 11:12 PM Thread Starter
I have a cooler from a 6.0 I just need time to put it on. I just figured temps that high may mean something is wrong. I will check the bypass tomorrow.
post #8 of 33 (permalink) Old 05-03-2012, 11:48 PM
There can be several things wrong. Two are listed above.
Mark
post #9 of 33 (permalink) Old 05-04-2012, 12:22 PM
tonka350's Avatar
I have a dumb question, I have my truck and driving daily temps on my stage 3 programming I'm running 210-220 degrees and I know that's WAY TOO HIGH!...where is this bypass located and how do I check if it's bad? right now I'm running 40" toyos on 3.73's but do nothing more than MAYBE 15 miles of highway at a time and no hills whatsoever. I am having it regeared this summer to 4.56's or 4.88's I haven't decided yet.
Chad
00 F350, 08 clone, 3" cowl hood,billet grilles, 15" lift, 40" SS M16'S, 24X12 Rockstars, 2% tint, EBPV Delete, 4" duals w/7" tips, 6637 intake, WW, CCV Mod, PHP 80,120 race,140 Extreme, stage 1 single shots, 6.0 I/C
Chad
tonka350 is offline
post #10 of 33 (permalink) Old 05-04-2012, 01:06 PM
Rock Steady
Think I might have copied this from one on Marks post awhile back.
I believe its a small black approx. 8"long and 3/8"dia. tube diagnoly placed on passenger side of trans , fastened with a banjo bolt at either end .
2000 F-450 Dump NLTD tunes
4duggan is offline
