transmission up grade?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-25-2012, 01:23 AM Thread Starter
I have an 2002 7.3 with the 4R100 and would like to up grade to a 6 speed auto. Im wondering witch transmission would be the best and most cost effective? Alison or maybe fords new one. Anyone do this too there truck?
02-7.3 is offline
post #2 of 9 (permalink) Old 03-25-2012, 02:20 AM
ToMang07's Avatar
Re: transmission up grade??
Most cost effective would be to just get a built 4R100.
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, PHP Phoenix-(STK-80dd-100P-120R-65T-40T) 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, Fisher 8' MM2. Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203*TS and Billet Housing, ELC, Fumoto, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing...~AE w/Ford Pack~
ToMang07 is offline
post #3 of 9 (permalink) Old 03-25-2012, 02:24 AM Thread Starter
True but want the performance of a 6 speed...
02-7.3 is offline
post #4 of 9 (permalink) Old 03-25-2012, 02:29 AM
ToMang07's Avatar
What performance? It's going to be slower since it has to take more time to shift.
There are guys upgrading from newer transmissions back to the 4R100.
And after buying another one, plus all the custom parts, (adapter, transfer case, driveshaft, etc) aftermarket tuner.... it's gonna cost you a lot more.
I don't think the allison is that great, anyway. I have a buddy with a 09 chebby and it's had the tranny rebuilt twice in under 50k miles.
ToMang07 is offline
post #5 of 9 (permalink) Old 03-25-2012, 01:43 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
How much money have you budgeted to do this? With the computer problems you'll run into I would bet that it would cost less money to give your current truck away free and buy a brand new loaded 2012.
Mark
Mark Kovalsky is offline
post #6 of 9 (permalink) Old 03-25-2012, 02:26 PM Thread Starter
So your saving it will cost 50,000 to put a 6sp in my truck? As far as it slowing my truck down, dont think so im not looking for 1/4 mile times. Im looking for better towing and fuel mileage. Im just asking to see if anyone has up graded there trucks to 6 speed transmission and whats a good transmission to use.
02-7.3 is offline
post #7 of 9 (permalink) Old 03-25-2012, 04:30 PM
Yes, I can see it costing that much. Here's why.
First, none of the six speed transmissions were built with a bolt pattern that will bolt to a 7.3L. You'll need custom adapters to make it fit. You'll also need to modify the trans crossmember and one or two driveshafts. That's the easy and cheap part. All of that shouldn't cost more than a grand or three.
Next, you'll need a wiring harness. You can probably get a stock one and modify it to work. Ever price a harness? With modifications to make it fit your truck, plan on another grand.
Now comes the fun part - what to do about a computer to run it? The stoock computer needs data from the engine computer to control the trans. The engine computer running your 7.3L doesn't have those outputs, nor the software that calculates what the transmission computer needs to see. The engine computer from the newer engines won't run a 7.3L, so you'll need to invent a computer to run the engine and one to run the transmission. Also, you'll need to create and program the software to control both. As far as I know nobody successfully made an aftermarket controller that could run the 5 speed TorqShift, and if they couldn't do that they sure can't make one that can run a 6 speed.
Creating the computers and software should easily eat up more than $50,000.
And that's why if you do this you will be the first person to do it.
Mark
post #8 of 9 (permalink) Old 04-02-2012, 01:40 AM
Custom Trailer Sales
TrailerHauler's Avatar
PCS http://www.powertraincontrolsolution...nscontrol.php#
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #9 of 9 (permalink) Old 04-02-2012, 02:02 AM
It doesn't say it will run a six speed auto. Good luck making it control this transmission.
On the other hand, go ahead and build one. Show that I'm wrong.
Mark
