04 powerstroke auto trans problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-22-2012, 03:43 PM Thread Starter
6.0stroken's Avatar
i have a 04 f-250 4x4 crew cab with the 5r110 auto trans. my trans has been going downhill fast. it takes a 5- 15 seconds to go into gear, it bucks and jerks after 2 gear and then towhaul light comes flashing, then doesnt shift into 5th gear at all. its does it all the time now. it did it while back and i shut the truck off uninstalled lonney wild tune and installed xrace and it went away far a month. so i bought gogo's direct clutch solenoid and it lasted for about 2 months and is now doing it all the time.
04 f-250 quad cabin 4x4 auto 5r110, 190cc 100%, upgraded oil cooler, upgraded fuel spring regulator, 6.4 banjos, airdogII, gogo's direct clutch solenoid, 5'' exhaust with no cat, sct 3015 with xrace,xstreet,looney wild,srl+,ddp,rcd,super panty dropper, arp headstuds, sinister coolant filtration, sinister egr delete, moderate tuned 58v ficm.
6.0stroken is offline
post #2 of 13 (permalink) Old 03-22-2012, 07:53 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 04 powerstroke auto trans problem
You need to find out what code is stored in memory. When the light flashed a code was stored. It will stay in memory even if the light isn't flashing any longer. The places that read codes free don't have the expensive tool to read trans codes, their cheap readers will tell you there is no code. Don't believe that.
Mark
Mark Kovalsky is offline
post #3 of 13 (permalink) Old 03-24-2012, 06:45 PM Thread Starter
6.0stroken's Avatar
ok the codes off my sct programer are.........p0766 : shift solenoid D (ss-d) perfromance of stuck off. and the other one is p2703 : trans friction element D apply time range/ performance.
post #4 of 13 (permalink) Old 03-24-2012, 07:42 PM
my did the same thing there were many metal to metal clutches
[White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Borg Warner 62/68/.88, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, PMF, S&B, Mishimoto rad/ic, 08 axle swap
scparrish is offline
post #5 of 13 (permalink) Old 03-24-2012, 09:24 PM
You have a failed solenoid. That caused the P0766. It also cause the P2703. Replace shift solenoid D. I don't have a diagram to tell you which one is D.
Mark
post #6 of 13 (permalink) Old 03-25-2012, 04:59 PM Thread Starter
6.0stroken's Avatar
i have replaced it with a gogo's direct clutch solenoid once before to prevent this from happening. does this mean its time for a new trany rebuild or just a faulty solenoid.
post #7 of 13 (permalink) Old 03-25-2012, 05:15 PM
Hard to tell from here. The codes indicate that the solenoid is bad, not the entire trans.
Mark
post #8 of 13 (permalink) Old 03-27-2012, 02:46 AM
that would be a lot cheaper. If you want a brand new factory solenoid bnib I have one for 100
post #9 of 13 (permalink) Old 03-27-2012, 09:21 PM Thread Starter
6.0stroken's Avatar
well i dropped the trans pan and its filled with gunk and pulled the solenoid and it looked fine. so i cleaned everything up and put the pan back on and filled it up. still acting up but i honestly think its fried the trans direct clutches so i gonna buy a stock trans with 88k on it and sell the truck.
post #10 of 13 (permalink) Old 03-28-2012, 01:16 AM
macoyle's Avatar
Lol, not sure why your gonna sell it unless that was the plan to begin with. Runnin those wild tunes is gonna tear stuff up, gotta pay to play brother
06 F-250 ccsb King Ranch, 2011 KR interior, 3" rough country lift, 35 toyo M/T's 20 XD Hoss wheels, RC dual stabilizer, SCT X3, WILDMAN tune, bumpers, Edge CTS, AMSOIL bypass kit, Dfuser coolant kit, etc.
2004 Toyota 4runner 3" lift Shrockworks bumper and 285's
macoyle is offline
