i need help/advice on a transfercase rebuild! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-21-2012, 03:39 AM Thread Starter
mra4x4's Avatar
ive got a 05 f250 that has a np273f transfer case.what happen was,my truck started making a scraping/grinding noise like a hub was bad so i jacked the truck up checked the hubs and nothing.so i put the truck in netural and took the drive shafts off and spun the back shaft to the rear wheels on the transfer case and found my noise.its coming from where the tranny slides in to the transfer case...the truck drives very well with no problems just the noise and i know it can not be good cause it sounds like sh**.im hoping it is just a bad bearing.now the transfer case is the only thing i have never taken apart on a truck and am geting ready to take it out but can find any info on how to rebuild it or replace bearings.can some one please give my ANY tips on this subject??thanks!
mra4x4 is offline
post #2 of 13 (permalink) Old 03-21-2012, 03:58 AM Thread Starter
mra4x4's Avatar
Re: i need help/advice on a transfercase rebuild!
come onn some one has to have taken one apart....
help me out here pleaseee
mra4x4 is offline
post #3 of 13 (permalink) Old 03-21-2012, 10:51 PM Thread Starter
mra4x4's Avatar
Any one....
mra4x4 is offline
post #4 of 13 (permalink) Old 03-22-2012, 01:27 AM
I just repaired mine and I had worn forks they had an update kit that my 99 needed. I had to replace my main shaft. I don't know if your year already has the upgraded shaft. If your familiar with wrenchin, it's pretty easy. For diagnosis your just going to take it apart and see, then get your parts. The hard part of the job is getting the snap rings of the shaft without ruining them by bending. These snap rings didn't come with my parts. You have to use a pair of snap ring pliers, you may have to try a couple of different kinds or enterchangable tips. bigger the better. the snap rings don't have holes. Be patent, if you can successfully do this part, the rest is cake.
Drew540 is offline
post #5 of 13 (permalink) Old 03-22-2012, 02:28 AM Thread Starter
mra4x4's Avatar
so to see what is making the noise just get the case open and look for wear or damage on the parts?and did u use gaskets or liquid gasket?thanks for the reply!i thouhgt iwas going to be going in to this blind
mra4x4 is offline
post #6 of 13 (permalink) Old 03-22-2012, 02:48 AM
there is no gasket. Yes liquid or ultra black permatex is fine.
Drew540 is offline
post #7 of 13 (permalink) Old 03-22-2012, 02:54 AM Thread Starter
mra4x4's Avatar
alright sounds good ill be taking it apart saturday thanks for the help
mra4x4 is offline
post #8 of 13 (permalink) Old 03-22-2012, 03:20 AM
Im tryin to upload a picture of mine opened up. i don't know if I'm doing it right.
Drew540 is offline
post #9 of 13 (permalink) Old 03-22-2012, 03:21 AM
It Worked !!
Drew540 is offline
post #10 of 13 (permalink) Old 03-22-2012, 03:56 AM Thread Starter
mra4x4's Avatar
thanks wow that looks alot easier than i thought!is there any thing i should know besides snap rigns being a pain when i take it apart.like springs of any type wanting to fly out at me??and this might sound dumb but when i take it off the truck should i drain it first?and did u use a jack im not sure what kind of weight to be expecting?
mra4x4 is offline
