What commands the shift to overdrive? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 09-04-2007, 12:56 AM Thread Starter
Is it a shift solenoid or what? The tranny hangs up on the shift to overdriveif you let off the gas it shifts. Only had this problem since the install of the transgo shift kit. THe hole in the accumulator plate is already drilled to about .110 for 4th gear
onefasttt is offline
post #2 of 3 (permalink) Old 09-04-2007, 01:11 AM Thread Starter
Re: What commands the shift to overdrive?
and also are the two sensors on the top of the transmission can they go in either location since they look the same? Or are they different and how can you tell the diference?
post #3 of 3 (permalink) Old 09-04-2007, 11:17 PM
X Racer
Racer X's Avatar
No, The A, B solenoids are off. Pressure thru the accumulator applies OD in short. Try checking the L mod and 3/4 reg circuits for sticky valves & proper assembly. Feedbolt torqued?
The sensors are the same unless you have PTO.
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
