e40d troubles please help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 03-17-2012, 04:12 AM Thread Starter
Powerstroke n00b
Justincredible's Avatar
Question e40d troubles please help
so i bought a 1995 f250 with the e40d, and it shifts into second terrible.
and by terribly i mean i have to get the truck up over 20mph/2500rpm and let off the throttle in order to get it to shift. this is the only gear that I have trouble with. Ive been trying to figure it out through other threads and I don't have the "experience" to diagnose this issue myself. I have 0 error codes (p1111). Ive read the my gauge cluster might need to be replaces, could be the vss. could be the solenoids in the transmission. Someone please help. cant really afford to cause any damage to my transmission.
Justincredible is offline
post #2 of 15 (permalink) Old 03-17-2012, 11:41 AM
Re: e40d troubles please help
What are you using to read codes?
02 f250
countryboyrob is offline
post #3 of 15 (permalink) Old 03-17-2012, 03:29 PM Thread Starter
Powerstroke n00b
Superchips muco tuner
post #4 of 15 (permalink) Old 03-17-2012, 03:32 PM
Might need to use something like ae or a scanner from snap on
02 f250
post #5 of 15 (permalink) Old 03-17-2012, 03:48 PM Thread Starter
Powerstroke n00b
We scanned it with a snap on scanner my uncle has. And still no codes. Thats why I'm so puzzled
post #6 of 15 (permalink) Old 03-17-2012, 05:55 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
How does it shift if you start with the shifter in 1 and move it to 2 when it should shift?
Mark
Mark Kovalsky is offline
post #7 of 15 (permalink) Old 03-17-2012, 06:19 PM Thread Starter
Powerstroke n00b
[QUOTE=Mark Kovalsky;1797252]How does it shift if you start with the shifter in 1 and move it to 2 when it should shift?[QUOTE]
post #8 of 15 (permalink) Old 03-17-2012, 06:46 PM Thread Starter
Powerstroke n00b
Havent tried doing it manually. Ill try and let you know
post #9 of 15 (permalink) Old 03-18-2012, 04:38 AM Thread Starter
Powerstroke n00b
It shifts manually. Not sure if that helps any.
post #10 of 15 (permalink) Old 03-18-2012, 11:57 AM
Of course that helps. Did you think I asked the question just do see if you'd try it?
When shifting manually the trans applies the intermediate band in second gear. That band is ONLY used when the shifter is in the 2 position. When the shifter is in D during the 1-2 shift the intermediate one way clutch has to hold. In a manual 1-2 shift the intermediate band holds the torque instead of the intermediate one way clutch.
This tells me that the intermediate one way clutch is failing. The trans has to come out and get torn down to fix this.
Mark
