may be a question that is ass backwards - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-14-2012, 02:04 AM Thread Starter
most guys want to lock up the TQ. mine locks up way too soon for around town driving when not towing and the truck bogs. I put a switch to cut the purple wire/yellow tracer when flipped, truck is awesome around town and can be flipped again for normal use. But if I get on it I get the flashing off light on the shifter, assuming for exsessive TQ slip. Im looking for a way to trick the ECU into thinking the TQ is locking up as it should. Or is there another way to keep the TQ locking until a higher speed or gear. If im wasting my time tell me now.
Tow rig - 1996 F-250 now a 350 7.3, 6637 intake, 3in dp, 4in straight pipe exhaust, 6 pos with PHP tunes, intercooler, gauges.
Wheeling rig - 1995 Jeep Wrangler, 4.0 turbo, spring over, Dana 60's, spooled rear locked front, 37's, full cage.
f250towrig is offline
post #2 of 3 (permalink) Old 03-15-2012, 05:45 PM
bracketracer's Avatar
Re: may be a question that is ass backwards
Look at Transtar's catalog. They offer a solenoid pack with an adjustable delay. You can only delay it so far, however, before the CEL comes on. Even a few milliseconds helps if your's is bogging. You don't have any other engine performance issues, right? If the engine's down on power for some reason it may seen like a trans issue.
Newest project: 1995 F350 CC/DRW 2WD E4OD. 3" DP, 4" Diamond Eye system. But I'm still fixin' the broken stuff......
bracketracer is offline
post #3 of 3 (permalink) Old 03-23-2012, 08:01 PM Thread Starter
engine power is fine, i have 3.55's, im sure 4.10's would help
