DO IT YOURSELF TRANSMISSION COMPLETE FLUSH. WORKS ON ALL TRUCK TRANSMISSIONS. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 02-21-2012, 02:17 AM Thread Starter
Here is what we do at work EVERY day. First remove the pan and replace the internal filter. Reinstall the pan and fill the trans to full mark. Then you want to OVERFILL yes overfill the transmission by about three quarts. Put transmission dip stick backin before you start the truck. Remove the line going BACK into the tranny from the trans cooler. Make sure its the return line. Put the line in a bucket. Start the truck for about 10 seconds. See how much fluid you have in the bucket. and repeat fill and start until the fluid is clean.. DO NOT RUN THE TRANNY DRY. This is why you are overfilling it at first.. It wont hurt anything and cause no damage to the internals by doing it this way. If you refill and do this once or twice until the fluid comes out clean you have flushed the converter, and cooler, and radiator cooler. Reinstall the transmission line that you removed and check to make sure your transmission is at the proper level. Why pay a shop 250-300 to do their half ass flush when you do it this way its done CORRECTLY.
Run either transynd or amsoil atf.
2002 F350 DRW, 38r Turbo, Terminator T500, REG return fuel system, CTS Evo Custom tuned by Bill at Powerhungry Performance, bts converter, S&B intake, Snows Stage 3 Water/Meth. Mcculloch hids 6k.
toypuller is offline
post #2 of 3 (permalink) Old 03-01-2012, 01:30 AM
Re: DO IT YOURSELF TRANSMISSION COMPLETE FLUSH. WORKS ON ALL TRUCK TRANSMISSIONS.
There is a sticky for this procedure ....
1999.5 F350 SuperCab, Auto, 4x4, 3.73, PHP tunes, PI Stallion, Tri-something-olator, Hutched/Harpooned, 6637, CCV, IAH delete, MBRP 4", Evans, 203 T-stat, Japanese drain valve, dyna-beads, 70K
two-rocks is offline
post #3 of 3 (permalink) Old 03-01-2012, 03:32 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
https://powerstrokenation.com/forums/...ead.php?t=4338
Mark
Mark Kovalsky is offline
