4r100 to zf6 swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 02-19-2012, 11:49 PM Thread Starter
4r100 to zf6 swap
ok having huge issues just finished a zf6 swap in my buddys 01 powerstroke which fyi was a bitch now the issue we are having is the clutch will not release we swapped out the master and slave cause we figured out it was the wrong one so we got the right one which was used and the clutch we put in was a used ceramic with a used pressure plate and we did have the flywheel resurfaced any help would be great thanks...
Clintreiner is offline
post #2 of 3 (permalink) Old 02-21-2012, 12:38 AM
Re: 4r100 to zf6 swap
Did you bleed the master/slave assembly completely? Can you see it move under the truck?
brickhead is offline
post #3 of 3 (permalink) Old 02-21-2012, 02:16 AM Thread Starter
its a pre bled system we got out of a junk yard truck
