Mark- 95 Bronco E4od question... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 02-05-2012, 10:29 PM Thread Starter
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Got a 95 bronco that we use from time to time for farm work and crap. It sits for months at a time without use.
When ever you jump in it to go somewhere for the first time you have to rev it a bit before the tranny will bite. It will just sit there, D or R doesnt matter.
Fluid could be bad I am sure, but its full. Bad pump maybe?
Nothing I am looking to build or anything, more then likely I'll just pick up a junk yard tranny when it finally goes.
Joe
CSIPSD is offline
post #2 of 2 (permalink) Old 02-05-2012, 11:41 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Mark- 95 Bronco E4od question...
It is probably the torque converter draining into the pan from sitting so long. Next time it sits a long time let it idle for about 20 seconds before trying to put it in gear.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
