4R100 Towing upgrade - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 02-01-2012, 12:37 AM Thread Starter
Using a 4r100 for towing. With out pulling the trans, what upgrades can/should be done? i.e Transgo shift kit or Transgo tugger kit?
I have already put a bigger cooler on.
Cheers Colin.
hienergy557 is offline
post #2 of 23 (permalink) Old 02-01-2012, 01:12 AM Thread Starter
Re: 4R100 Towing upgrade
Also, what tuner do you guys suggest (in tow mode)
I don't need any more power, I just want the auto to survive.
Cheers Colin
post #3 of 23 (permalink) Old 02-01-2012, 02:36 AM
zilla68's Avatar
I'm looking at either racerx or bts for a valve body upgrade and shift kit.
how many miles on the tranny?
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #4 of 23 (permalink) Old 02-01-2012, 11:30 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
I would never use any tuner on a trans that I wanted to last. A better cooler is all you need.
Mark
Mark Kovalsky is offline
post #5 of 23 (permalink) Old 02-01-2012, 09:07 PM Thread Starter
So Mark, none of the programers help the auto survive? Here in Australia everybody says the Edge Evolution programer in tow mode helps the auto.
Is that not true?
Also are the shift kits a waste of money as well?
Cheers Colin.
The truck has about 80,000 miles on it.
post #6 of 23 (permalink) Old 02-03-2012, 02:04 AM
I think some of the shift kits can help. It is my opinion that none of the tuners will help with transmission life. But that's just one engineer's opinion.
Mark
post #7 of 23 (permalink) Old 02-03-2012, 02:27 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
You cant add more power and expect better tranny life.
Joe
CSIPSD is offline
post #8 of 23 (permalink) Old 02-03-2012, 06:46 PM
Depending on the miles..add a BTS VB a 6.0 Tq converter and a 31 row trans cooler..good tunes will not hurt the trans..TS chip with custom tunes.
email:
Website:
OBSWIZ is offline
post #9 of 23 (permalink) Old 02-03-2012, 06:59 PM
Bmiller5's Avatar
Does the 5r110 two converter go right into the 4r100?
Bmiller5 is offline
post #10 of 23 (permalink) Old 02-03-2012, 07:45 PM
jaybuller's Avatar
I would like to know as well.....I figured the convertor bts uses would be the one to get
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
