e4od/4r100 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 01-22-2012, 11:10 AM Thread Starter
cfsmith1987's Avatar
e4od/4r100
What tranny is in e99 powerstroke
E99 f-350 psd 4" mbrp/ ts chip / bts tranny/ procomp 37/13.50 on 20 in moto metal wheels s and b air.intake/ 6" rough country susp lift...250/200 injectors s476 with irate mount , twin superduty pumps with regulated return , cales tunes . Head studs ,valve springs , pushrods, dyno numbers Coming soon . T500 hpop
cfsmith1987 is offline
post #2 of 10 (permalink) Old 01-22-2012, 02:57 PM
mroutlawoffroad
OUTLAW-OFFROAD's Avatar
Re: e4od/4r100
Bump id like to no 2
96 cclb 10" lift 38" tires.
6 pos custom tuned chip, AD injectors, hoodstack, fpr shim,isspro gauges, electric fans, Built trannismission.
OUTLAW OFFROAD traction bars.
OUTLAW-OFFROAD is offline
post #3 of 10 (permalink) Old 01-22-2012, 03:39 PM Thread Starter
Re: e4od/4r100
I have read it could be Either but Im not sure . I could probally call bts and Find out. Anyone know the Difference in the two from bts trannys
post #4 of 10 (permalink) Old 01-22-2012, 10:29 PM
Stone Crusher
trackspeeder's Avatar
Re: e4od/4r100
4R100
01 F250 XLT 4X4 Auto trans, Dark Highland Green, Green fuzzy dice,Di Pricol Optix gauges,Dura Lite air cleaner,CCV mod,coolant filter,,AIC,XM Satilite radio.
trackspeeder is offline
post #5 of 10 (permalink) Old 01-22-2012, 10:35 PM
Re: e4od/4r100
4r100 is the auto in a 7.3 sd, e4od is the auto for the psd obs. A 4r100 can work in a obs but a e4od can't work in a sd.
02 f250
countryboyrob is offline
post #6 of 10 (permalink) Old 01-22-2012, 10:41 PM
mroutlawoffroad
Re: e4od/4r100
They look the same to me is there any way to tell them apart I have 1998 ambulances with E99 Engine, trans looks the same as my 96 truck
post #7 of 10 (permalink) Old 01-22-2012, 11:17 PM Thread Starter
Re: e4od/4r100
Thanks
post #8 of 10 (permalink) Old 01-23-2012, 03:55 AM
bracketracer's Avatar
Re: e4od/4r100
The 4R100 will have a turbine shaft speed sensor (an input shaft speed sensor) that the E4OD never came with.
bracketracer is offline
post #9 of 10 (permalink) Old 01-23-2012, 10:12 AM Thread Starter
Re: e4od/4r100
Ok thats What i needed
post #10 of 10 (permalink) Old 01-23-2012, 12:23 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: e4od/4r100
The 4R100 has two sensors on top, the E4OD has none.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
