transmission slack zf6 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 01-16-2012, 12:47 PM Thread Starter
I am not sure if the zf6 has slack or could a transfer case chain cause slack?
has slack when you get in or out of the throttle... I have not checked the rear end yet. I plan on checking the rear end with a dial indicator when I change the fluid. Spinning the drive shaft does not seem to show that much wear.... so that kinda has me puzzled
2002 f250 4x4 ccsb 7.3, auto with tugger,6.0 cooler,pyro/boost/fuel/transmission gauges, 4inch diamond eye straight pipe, ebb delete, bd billet wheel, diy tymar intake, ccv delete mod, fp shimmed 65psi, hpox-over, php6 pos chip(stock,1100, 65t,80dd,100perf,120race, coolant bypass-filter,203 dieselsite thermostat, stancor gpr/led indicator light,
01powerstrokin is offline
post #2 of 12 (permalink) Old 01-16-2012, 01:22 PM
Haters Gonna Hate
Fordfreak4life's Avatar
Re: transmission slack zf6
U joints
Fordfreak4life is offline
post #3 of 12 (permalink) Old 01-16-2012, 05:33 PM
SUPERDF350's Avatar
Same problem that I had. Felt like there is slack in the drive train. Lube the slip joint on the drive shaft. With axle rap the slip joint moves in and out. When I heard this I call ed B.S. but I tried it and it fixed my problem. I used WD-40 to test it out. I put the straw through the hole but the u joint and filled it up full.
2003 F-350 CCLB 4x4 6 spd man 5.5 Fabtech, 4"turbo stright piped,DP Tuner, hi-idle,40,60,80,100,120, ATS housing wicked wheel, tymar intake,firestone airbags.
SUPERDF350 is offline
post #4 of 12 (permalink) Old 01-17-2012, 12:21 AM Thread Starter
Thanks! I'll give it a try
post #5 of 12 (permalink) Old 01-19-2012, 09:16 PM
STILL LEARNING
Bradbilt's Avatar
Nature of these manual trans
Bradbilt is offline
post #6 of 12 (permalink) Old 01-25-2012, 08:12 AM
Custom Trailer Sales
TrailerHauler's Avatar
I've had three zf6's now and they all seem to have a little "slop". It's not a super tight transition when you go from spinning the driveshaft to the driveshaft spinning the trans.
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #7 of 12 (permalink) Old 03-09-2012, 08:19 PM Thread Starter
i put a zerk fitting in the slip yoke. greased it with mobil 1 synthetic grease. It helped a little bit. Is there a certain type of grease to use?
post #8 of 12 (permalink) Old 03-10-2012, 12:06 PM
Send a message via AIM to Barnbuilder
I have the same issue. I know part of it is the rear end. I jacked up the rear and rotated the tire front and back annd the pinion shaft would shift 1/8". Need to find someplace to rebuild it
1999 F350 CC XLT 4x4 6spd
2006 F350 CC KR 4x4
Barnbuilder is offline
post #9 of 12 (permalink) Old 03-11-2012, 02:03 PM
STILL LEARNING
Bradbilt's Avatar
You are going to have play, even in a NEW rear. You will be waisting your money
Bradbilt is offline
post #10 of 12 (permalink) Old 03-11-2012, 03:27 PM
I don't think the pinion shaft should run in and out of the housing an 1/8" by reversing the tire rotation. My '06 doesn't move at all. It can't be good on the gears and bearings.
2006 F350 CC KR 4x4
