Clutch Adjustment on a 6 speed - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #11 of 13 (permalink) Old 11-17-2018, 11:24 PM
Question Re: Clutch Adjustment on a 6 speed
How many miles can I expect out of a clutch?
Trustroke is offline
post #12 of 13 (permalink) Old 11-18-2018, 10:17 AM
alleged moderator
tjctransport's Avatar
depends on how you drive. i had one truck that still had the original clutch in it when i sold it at 255,000 miles.
and i also had trucks come into the shop needing clutches at 45,000 miles
tom
tjctransport is offline
post #13 of 13 (permalink) Old 11-22-2019, 05:33 PM
Originally Posted by MTW View Post
You're right on two accounts, 1rst- clutch mechanics are a joke on these trucks...2nd-removed slave and operated piston 4 times, now have great pedal. Hope it lasts. Thank you for the post.
MTW
I know this is a little old but very relevant because cycling my push rod helped.
I have a 1999 v10 5 speed, removing slave pushing rod in 5 times and allowing return spring to return push rod worked on mine as well. My push rod had enough free play to let my throw out bearing squeal just a little when clutch released because it didn't have enough pre-load. Trying to figure out what the cycling of the push rod is doing to take up the push rod slack since it has an internal return spring. very interesting and I really wish I had my old slave to cut apart and see how in the world that helped.
tdupriest is offline
