Overdrive - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 08-21-2007, 09:05 PM Thread Starter
Overdrive
My 97 psd keeps blowing the overdrive fuses and I was wondering if anyonr could tell me why?
Jason Reimer is offline
post #2 of 11 (permalink) Old 08-21-2007, 10:26 PM
Failure to Communicate
highfive's Avatar
Re: Overdrive
Overdrive fuse?
Which fuse number in the panel?
96 F250 CC SB 4x4
DIY or Die Tryin-Fuel, Trans, Lifted and Stroked
highfive is offline
post #3 of 11 (permalink) Old 08-21-2007, 10:37 PM
Lurker...
Fever's Avatar
Re: Overdrive
do you have the OD On/Off pushbutton on the shifter of a '97?...if so the wires might be frayed under the dash and shorting...
2003 F-350 Super Duty
Fever is offline
post #4 of 11 (permalink) Old 08-21-2007, 10:39 PM
Corona Killa
THEDIESELMAN's Avatar
Re: Overdrive
I know my dads old truck had a od on off but it was a button on the dash either way check out the wires going it.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #5 of 11 (permalink) Old 08-24-2007, 01:38 AM
X Racer
Racer X's Avatar
Re: Overdrive
Yup, check the wiring from the shift lever down the column. Look for pinch points. A short will blow the dash fuse.
Racer X is offline
post #6 of 11 (permalink) Old 08-24-2007, 11:49 PM Thread Starter
Re: Overdrive
I did check the wires and it was pinched but now I still have the column cover off and it still does it???????
post #7 of 11 (permalink) Old 08-25-2007, 03:25 AM
OEM Moderator
Tom S's Avatar
Re: Overdrive
Does it blow the fuse right away or does it take a while?
Tom
Tom S is offline
post #8 of 11 (permalink) Old 08-25-2007, 05:17 AM
X Racer
Racer X's Avatar
Re: Overdrive
You still have a short is why, keep looking. It can short in the button itself. Then you need a new lever.
Racer X is offline
post #9 of 11 (permalink) Old 08-28-2007, 01:47 AM Thread Starter
Re: Overdrive
Lever has been replaced twice.It usually takes a while to blow
post #10 of 11 (permalink) Old 08-28-2007, 05:00 AM
X Racer
Racer X's Avatar
Re: Overdrive
Hard to track down something like that. See if you can find a circuit breaker same amp rating as the fuse. Then you can wiggle test the harness and listen for the breaker to pop.
Racer X is offline
