antifreeze - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-19-2011, 05:30 AM Thread Starter
Clifford05's Avatar
antifreeze
has any one put an sct x3 on a 6.0 and ran it on performance and had antifreeze leak out of the cap i wasnt sure if that was a common problem but it only happened after i put the programmer on my truck and is there any caps with a better vent on it to release some pressure or is there another way to fix that
Clifford05 is offline
post #2 of 9 (permalink) Old 03-19-2011, 05:39 AM
Marc's Avatar
Re: antifreeze
Could be a few things. Anytime you run a "hotter" tune you are going to amplify a problem.
It could be as simple as a bad cap.....
You could have an oil cooler with a restriction on the coolant side of the oil coooler.
You could have an EGR cooler getting ready to fail (pretty uncommon though on 03 and early 04 6.0's)
You could have a headgasket (or more accurately stretched headbolts) that are only bleeding compression into the cooling system under the highest of boost pressures
If the oil cooler is ok, As long as it doesnt get too bad, it generally isnt a problem, but if the oil cooler is restricted you are hurting the lubricating quality of the oil faster than you should.
Put a new cap on it and see what happens. (get a ford cap). If that doenst fix it we can go from there.
NHRDA Region 2 Race Director
Marc is offline
post #3 of 9 (permalink) Old 03-19-2011, 06:00 PM Thread Starter
Clifford05's Avatar
Re: antifreeze
Ok and thanks ill go pick one up soon
post #4 of 9 (permalink) Old 03-19-2011, 06:03 PM Thread Starter
Clifford05's Avatar
Re: antifreeze
Ok and thanks ill go pick one up soon (today hopefully)
post #5 of 9 (permalink) Old 03-24-2011, 10:36 PM Thread Starter
Clifford05's Avatar
Re: antifreeze
My cap only seems to leak when I really get into it so does that mean anything like maybe it is jus the cap or something else?
post #6 of 9 (permalink) Old 08-25-2011, 03:34 PM
Re: antifreeze
head gaskets blown is prob more then likely what it is
rdonovan is offline
post #7 of 9 (permalink) Old 10-21-2011, 02:43 AM
COMPUTER BLUE
airfish2011's Avatar
Re: antifreeze
x2
lots of 6.4's and a few 6.0's
airfish2011 is offline
post #8 of 9 (permalink) Old 10-28-2011, 05:17 PM
haulin2000's Avatar
Re: antifreeze
you are lifting the heads under high boost.... stretched bolts... blown head gasket... fix it and the egr at the same time dont forget the arp studs too or you will be doing it again.. my first diesel was a 6.0 same problem.. i now have a 7.3 not that its perfect or anything
haulin2000 is offline
post #9 of 9 (permalink) Old 01-09-2012, 08:15 PM
Media Mushroom Stamp
spastik monkey's Avatar
Re: antifreeze
I'm having the same issue. However, i'm not getting the bubbling like you normally would. Possibly a blocked cooler?
spastik monkey is offline
