Shellzone Coolant for 97 Diesel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 02-28-2011, 10:50 PM Thread Starter
Coueshunter's Avatar
I bought Shellzone coolant. It meets ASTM D4985 and ASTM3306 and is green which is what Gooch says it needs to be for tese trucks. It is not listed on the bottle anywhere low silicate. If it meets ASTM D4985 does that mean it is low silicatE?
I also bought a bottle of Fleetguard DC4 as well.
Back the Blue BUILD THREAD
POWERSTROKENATION-
Facebook-
Coueshunter is offline
post #2 of 3 (permalink) Old 03-01-2011, 05:24 PM Thread Starter
Re: Shellzone Coolant for 97 Diesel
no one???
POWERSTROKENATION-
Facebook-
post #3 of 3 (permalink) Old 03-01-2011, 05:59 PM
Gooch's Avatar
ASTM D4985 is the standard spec for low-silicate coolant for heavy duty engines. The ASTM D4985 coolant plus an SCA (either DCA-4 or DCA-2) is what your particular build date engine would require. So by adding SCA to that heavy-duty low-silicate coolant you're good to go.
Note: If you see ASTM D6210, it is basically ASTM D4985 with the SCA already in the coolant (ASTM D6210 = ASTM D4985 + SCA): Typically called pre-charged. ASTM D3306 is just the most basic standard spec for coolant...you'll need more than just that spec alone for a diesel.
01 F350 PSD 4X Crew Auto SRW
WD chip, turbo filter, guages. Walker straight-thru, APCM, Astrostart, Custom 4X shifter, ProHeat oil heater, Rancho RS9000's, WeatherTech's, Husky liners, Aircraft lights, TorkLift tie-downs, Line-X, Custom hitch, toys to pull and haul.
09 Hyundai Sonota Lmtd
04 Ford F-150 4X4 SC
83 Toyota Supra
Gooch is offline
