Which AMSOIL Synthetic for an '02 ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 02-16-2011, 02:39 PM Thread Starter
Which AMSOIL Syntheic should be used in an '02?
It looks like they make 2 version of a fully synthetic oil.
One appears to be marketed towards 2007 and later diesels.
Premium API CJ-4 Synthetic 15W-40 Diesel Oil
And the other is marketed towards pre 2007 diesels
Synthetic Diesel & Marine Motor Oil SAE 15W-40
Would the 2007 and later oil be a better / superior choice over the pre 2007 oil?
bill4d is offline
post #2 of 17 (permalink) Old 02-17-2011, 05:39 AM
Re: Which AMSOIL Synthetic for an '02 ?
Either should be fine, but check your owners manual to see if they require CJ-4. I run Amsoil bumper to bumper.
bullbasin is offline
post #3 of 17 (permalink) Old 02-17-2011, 01:33 PM
Exploding the magma
rufushusky's Avatar
Either will work fine, a 5W-40 will give you better cold flow protection.
7.3s IIRC are set up to CH or CF, way before CI-4,CI-4+ or CJ-4. Any CI-4 and up oil will run just fine in a 7.3.
2002 F-350 ECLB SRW 7.3 4R100
6637 203* t-stat 08 diff cover Stancor HPX 6.0 trans cooler, Zone offroad leveling kit, Western UM 8'6" plow
Sold: 2004.5 Ram 2500 w/ 5.9 CTD, Reg Cab 48re
rufushusky is offline
post #4 of 17 (permalink) Old 02-17-2011, 10:13 PM Thread Starter
I am not considering a 5W-40 oil.
The two oils in question are both 15W-40. They are two different synthetic versions made by AMSOIL.
I'm trying to figure out if there is a benefit to the more expensive synthetic version marketed towards 2007 and later vehicles.
bill4d is offline
post #5 of 17 (permalink) Old 02-17-2011, 10:21 PM
Exploding the magma
rufushusky's Avatar
Ok any particular reason you are eliminating 5w40 oil?
Either one will work fine.
Ci-4+ oil lend themselves to longer OCIs due to higher TBN numbers but the CJ-4 (post 2007) will do better against soot. Either one will work fine, I would just run whichever one is cheaper.
post #6 of 17 (permalink) Old 02-17-2011, 11:01 PM
5W-40 is still a "40 weight" when its warmed up. If you live in a real cold area in the winter the 5W is a pretty good advantage with the HEUI system and cold starts.
TheDirt is offline
post #7 of 17 (permalink) Old 02-18-2011, 12:38 AM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
I run 5W40 year round... Never a problem cold starting, even in the negatives... not plugged in....
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #8 of 17 (permalink) Old 02-19-2011, 05:06 PM Thread Starter
I'm in NC, so the truck only sees temps in the teens a couple times a year.
bill4d is offline
post #9 of 17 (permalink) Old 02-19-2011, 05:21 PM
Exploding the magma
rufushusky's Avatar
Ok, well if your not worried about cold starts then I don't think a synthetic is really worth it IMHO. But you are set on Amsoil whichever one is cheaper should take care of you fine.
post #10 of 17 (permalink) Old 02-19-2011, 05:43 PM
Sponsor
04stroker's Avatar
Do the pre 2007 it works great and is cheaper I've run both in my 04 didn't notice a diffrence in the two so I run the one they recommend and is cheaper.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
