Transfer Flow Tanks - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-31-2011, 02:35 AM Thread Starter
Transfer Flow Tanks
I am chasing down a miss in my 2002 F-550 Rollback. It has a transfer flow tank on it now as part of the upfitter package. Now for my question, does anyone know if the transferflow tank carry over the Ford parts...Like the mixing chamber with the screens that get clogged?
LBZ_Duramax is offline
post #2 of 6 (permalink) Old 01-31-2011, 07:21 AM
Dead Member
Marauder's Avatar
Re: Transfer Flow Tanks
No they don't.
All the tank does is to dump fuel into the main tank. The electrical system is mostly independant as well. It does take low voltage signals to trigger the the IC chip.
2001 F350 7.3 SD EC LB 4X4 Handshaker, Water/Meth Injection, GQSSB W/Carson Stauffer mount, Swamps 250/200 injectors, TE Duals, Fuelab/Sump, Spearco, FS 2500, Fluid Dampner, ARP head/Main studs, Sinister R/R, Detroit locker out back, etc.
Marauder is offline
post #3 of 6 (permalink) Old 01-31-2011, 12:54 PM Thread Starter
This is tank that replaces the factory tank. Does that make a difference?
post #4 of 6 (permalink) Old 02-01-2011, 01:49 PM
CGMKCM's Avatar
If it is the Transfer Flo mid tank 34 Gallon then it uses the ford sender/pick up assembly.
My truck is 2001 F-550 with mid tank.
I dropped my tank last year do to a sender problem.
I called Transfer Flo and asked for the replacement part # for the assembly. At first they said it was there part # but they would have to call me back with price and availability.
When Transfer Flo called back they stated that it is the Ford sender assy. and they gave me the Ford Part #.
As it turned out, I was able to repair my problem and I did the In tank mod and pre-pump mod while I had the tank dropped.
I bought the in tank and pre pump kit from D.I.
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #5 of 6 (permalink) Old 02-01-2011, 10:01 PM Thread Starter
What classifies it as a mid tank? It is a rollback F-550 if that matters. 34gal sounds about right though. If it comes down to it, all I would have to do is just raise the bed and work on it.
post #6 of 6 (permalink) Old 02-02-2011, 01:48 PM
CGMKCM's Avatar
What I meant by mid tank is that the tank fill is close to the back of the truck cab, and the tank sits ahead of the rear differential.
Do you have a Transfer Flo sticker on the drivers door jamb? It will give you the model and size.
I would bet you have the same tank that mine has. It makes up fitting easier because of tank location.
Tilt your bed will make this a very easy job compared to dropping the tank. I would look into the in tank mod and pre pump mod while you have the sender out.
[SIGPIC][/SIGPIC]
BTS Tranny
PHP Phoenix chip
Adrenalin
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
