shortening versus WVO - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-23-2008, 05:16 PM Thread Starter
any reason not to use shortening? ive got about 5 gallons, gonna mess with it some. seems thicker, but its not hard or anything. what do you all suggest?
PMRCM#1
slowleak is offline
post #2 of 10 (permalink) Old 03-23-2008, 05:21 PM
<----Colin Banks
mattymx's Avatar
Re: shortening versus WVO
It will work if heated. But test it with some #2 in a bottle or something before you add it to your tank. See how it reacts and at what temp.
mattymx is offline
post #3 of 10 (permalink) Old 03-23-2008, 05:26 PM Thread Starter
ive got it cooking right now. im thinking 50/50 mix...i did notice that some of it settled when left in the jug...looks like a layer of fat almost. im thinking a good week to let it settle just to see what happens
PMRCM#1
slowleak is offline
post #4 of 10 (permalink) Old 03-23-2008, 05:54 PM
Stimulated
mattgw86's Avatar
I've heard that you shouldn't use shortening if you blend it. It settles out i think. Mix some with some diesel and put it in a bottle or something and let it sit for a couple days. Better yet, bring the shortening by my work tomorrow and we can put it in a beaker or a graduated cylinder so we can really see what it does.
1995 Chevrolet C1500 6.5
1995 Z28 w/ 2.73's
mattgw86 is offline
post #5 of 10 (permalink) Old 03-23-2008, 06:06 PM Thread Starter
matt can you come by the station? im workin on it right now. got it up to 200*, seems pretty good at that temp.
i can actually see the "brown" stuff starting to sperate from the "good" stuff now. i geuss its the burned part of the oil seperating from the good part?
PMRCM#1
slowleak is offline
post #6 of 10 (permalink) Old 03-23-2008, 06:08 PM
Starting Over
kainers's Avatar
You can't use shortening unless it is heated.I think also the fat will leave deposits in your fuel lines.Kinda like cholestrol in your heart.
kainers is offline
post #7 of 10 (permalink) Old 03-23-2008, 06:12 PM Thread Starter
yikes geuss thats a no then.
this is liquid shortening, it comes in liquid form. i figured after mixing with diesel it might thin out enough to be used.
oh well!
PMRCM#1
slowleak is offline
post #8 of 10 (permalink) Old 03-23-2008, 06:27 PM
Starting Over
kainers's Avatar
You can try it but I really think your fuel lines will get funked up for sure.
Now you could use it to make a small batch of bio.Check the titration and get to mixing.
kainers is offline
post #9 of 10 (permalink) Old 03-23-2008, 07:34 PM Thread Starter
titration? i think i will pass. i wanna stick to something simple, just filter mix and use
PMRCM#1
slowleak is offline
post #10 of 10 (permalink) Old 03-23-2008, 10:32 PM
Go Away I'm Baitin
fishinfool98's Avatar
Send a message via AIM to fishinfool98
doug
dont chance it, its not worth it
the only way i know to use the liquid shortening is to heat it up and run it threw a centrifuge and by the time you get threw doing this process its going to cost you more in electricity than its worth
A centrifuge cost around 400.00 and the pump to run it plus the plumbing and the tanks to keep it in
Other than that its only good for BIO
06 CCLB SRW grey first mod was PSN sticker
Sailors may come
Sailors may go
Tis the engineer below
That makes it Suck, Push, Bang, and Blow
"Closed due to EXPLOSIVE diarrhea, will be back when the EXPLOSIONS are over!"
fishinfool98 is offline
