synthtic tranny fluid worth it? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-14-2008, 11:37 AM Thread Starter
panteramatt's Avatar
Going to be changing the tranny fluid and Im wodering if its worth the $ to switch to synthetic?
panteramatt is offline
post #2 of 6 (permalink) Old 03-14-2008, 11:46 AM
A Ghost these days.
mad_matt's Avatar
Send a message via Yahoo to mad_matt Send a message via Skype™ to mad_matt
Re: synthtic tranny fluid worth it?
Yes without a doubt. If you're making the switch I'd have the trans flushed with a machine. You'll need 20 to 25 qts to make the switch.
You can mix dino and fully syn but it degrades the syn fluid. Most good shops will do a fluid exchange for 70-100 bucks.
Got Boost?
Slightly modded 01 F350 CC SB 4X4
Powered by Oil driven by Madness.
Post Injector upgrade Spin: 577/944
Dynojet
HP: 597 BWD Superflow
13.152 @ 104.7 mph
Mods: Everything plus the Twins.
In the mail: Everyone's stuff but my own
Planned upgrades: sho mods!
mad_matt is offline
post #3 of 6 (permalink) Old 03-15-2008, 03:58 AM
Soon to be a 6.4
lildevil02's Avatar
Send a message via AIM to lildevil02
I changed over to Royal Purple when I had my BTS installed. Do it and never look back. Temps are down a bit also.
lildevil02 is offline
post #4 of 6 (permalink) Old 03-15-2008, 12:56 PM
Freedom is not free
White Buffalo's Avatar
Why did you change to Royal Purple when BTS uses Schaeffer's Synthetic Tranny fluid in all his trannies? Just curious.
Synthetics will hold up to much higher temps, so if you tow alot it's definitely a good idea to change to synthetics IMO. Then instead of changing the synth tranny fluid at a set mileage interval send in a sample to an oil analysis lab like Schaeffer's ($9) or Blackstone Labs ($22) to determine when the fluid needs to be changed. I've seen used oil analysis reports on synthetic transmission fluids going a long, long, way.
White Buffalo is offline
post #5 of 6 (permalink) Old 03-15-2008, 05:18 PM
Soon to be a 6.4
lildevil02's Avatar
Since I had the tranny shipped to me, they couldn’t ship it with fluid. I talk to Brain a few times and he told that he had use RP before and also like it.
Now for RP.....I have been around the strip a few time in the last 4-5 years and everywhere I turn people are swearing by RP....I had never used them before but after my buddies took his Powerglide apart for some upgrades, it show for it self.
post #6 of 6 (permalink) Old 03-15-2008, 07:48 PM
Freedom is not free
OK, you had it shipped - that's why... just curious
