changin all my fluids - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-27-2008, 05:35 PM Thread Starter
panteramatt's Avatar
I have a few questions before I go changin all the fluids in my 2000 srw psd.
1. Im going to be using mobile 1 for the t.case, tranny, and ps pump. How many quarts will I need for all of them? Will 25 do it and I will be replacing the tranny filter and adding a jw vb and draining the tc.
2. How many quarts of oil for the rear? Using RP.
3. How do I know when the t-case is filled?
4. Is switching to synthetic rotella worth the extra $ and will the 5w40 be ok for summer?
panteramatt is offline
post #2 of 4 (permalink) Old 02-28-2008, 05:19 AM
Dieselgeek's Avatar
Re: changin all my fluids
These are the numbers for an 02, but shouldn't be far off for you...
Front axle- 2.9 qts
Rear axle- 3.45 qts
PS Pump- Not sure
T case- 2 qts
Tranny (assume you have 4r100)- 17.7 qts
To check the t-case... When you add fluid into the fill plug, fluid will start coming out once it is full... You can't add anymore. Word of caution, before draining the old fluid from your tcase, or tranny, make sure you can get the fill plug out first, if you can't and you drain fluids, you are screwed as you won't be able to add new...
As for Synthetic 5w40, I run it year round... From -20 to 95 degrees...
2002 F350 Reg Cab,4x4,7.3,6Spd.
Dieselgeek is offline
post #3 of 4 (permalink) Old 04-10-2008, 04:45 PM
Village Idiot
southmike's Avatar
Front axle- 2.9 qts
Rear axle- 3.45 qts
PS Pump- Not sure
T case- 2 qts
ouch good advice..you find out the hard way?
southmike is offline
post #4 of 4 (permalink) Old 04-10-2008, 06:15 PM
Proud PSN Sponsor
Deputydog's Avatar
Power steering is just fill until it goes to the full line..
MERCON Multi-Purpose Automatic Transmission Fluid XT-2-QDX
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
