Rotella 0w40 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-18-2008, 03:34 PM Thread Starter
Sofa King Cool
BMac's Avatar
Send a message via AIM to BMac Send a message via MSN to BMac Send a message via Skype™ to BMac
Rotella 0w40
Just wondering if anyone has run this? I found it local when I was looking for the 5w40, its definatly not cheap but so far its all i've found
People Fly Airplanes, Pilot's Fly Helicopters
2002 F350 Extended Cab Shortbed
1977 Early Bronco
BMac is offline
post #2 of 9 (permalink) Old 02-18-2008, 05:45 PM
Sponsor
airflo71's Avatar
Re: Rotella 0w40
If it was 0W 30 maybe but basically you got straight 40 w oil all the time.
airflo71 is offline
post #3 of 9 (permalink) Old 02-18-2008, 11:12 PM
Caption This
444-4D's Avatar
Re: Rotella 0w40
I don't think you are going to find many that are using it. I don't even think it is sold in the U.S.. I had never heard of it so I looked at the Shell website. It is a CG-4/SJ spec oil. So if those specs are ok it should be as good as it gets for cold climates.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #4 of 9 (permalink) Old 02-19-2008, 04:22 PM
Re: Rotella 0w40
I would use it only in very cold climates.
gregrob is offline
post #5 of 9 (permalink) Old 02-19-2008, 05:27 PM Thread Starter
Sofa King Cool
BMac's Avatar
Re: Rotella 0w40
Yeah thats what I was thinking, the pour point is -48 C, and even up here it doesn't get that cold too often
1977 Early Bronco
BMac is offline
post #6 of 9 (permalink) Old 02-21-2008, 04:17 PM
Darwin was right
F350DRW1's Avatar
Re: Rotella 0w40
How much $ are they getting per gallon for this oil?
This space for rent
F350DRW1 is offline
post #7 of 9 (permalink) Old 02-21-2008, 04:32 PM Thread Starter
Sofa King Cool
BMac's Avatar
Re: Rotella 0w40
29.99/ 4 liters (gal) Cdn
1977 Early Bronco
BMac is offline
post #8 of 9 (permalink) Old 02-21-2008, 04:43 PM
A Ghost these days.
mad_matt's Avatar
Send a message via Yahoo to mad_matt Send a message via Skype™ to mad_matt
Re: Rotella 0w40
I'd run it cause it's cold flow properties are like 0 (zero weight) and it's warm properties are like 40w. To sum it up. It will protect you engine better on cold starts because it will be easier to pump but as the oil heats up it will take on the properties of 40. It might also help your fuel economy a bit and I'd venture to bet that you could run it a lot further than 10K KM. That's the reason most American manufactured have switched over to full synthetic 0W20 or 0w30 oils in gassers. I run Mutoil 0W40 506.1 in my Bug as it's has better cold flow properties and an additive package than the 5w40 505.1 speck oil VW requires for the PD TDIs.
It's also is capable of extending the Drain intervals another 5K miles but I don't push it. It's funny how in Europe the oil drain interval is 1 year 30k onall of the VWs and it's 5 or 10K here in the use depending on the base oil std that the car uses. Can anyone read into the Jiffylube 3 months or 3k BS that's still stuck in the consumers head.
Who knows that might be where the extra 10HP came from. Less friction??????
Got Boost?
Slightly modded 01 F350 CC SB 4X4
Powered by Oil driven by Madness.
Post Injector upgrade Spin: 577/944
Dynojet
HP: 597 BWD Superflow
13.152 @ 104.7 mph
Mods: Everything plus the Twins.
In the mail: Everyone's stuff but my own
Planned upgrades: sho mods!
mad_matt is offline
post #9 of 9 (permalink) Old 02-22-2008, 01:01 AM Thread Starter
Sofa King Cool
BMac's Avatar
Re: Rotella 0w40
Okay thats what I was thinking on my limited understanding of oil weights, maybe i'll give it a go on my next change if I can't get the 5w40
1977 Early Bronco
BMac is offline
