Best Synthetic Oil - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 35 (permalink) Old 02-01-2008, 03:11 AM Thread Starter
Best Synthetic Oil
I have been using regular oil for my early 99' F250 but i want to start using synthetic. Whats the best synthetic oil to use?
Early 1999 F250 PSD
Air intake
4 inch turbo back exhuast
Stage 3 Hybrid injectors
6 stage 140 hp chip
performance rebuilt transmission
GotGMHP is offline
post #2 of 35 (permalink) Old 02-01-2008, 03:14 AM
All done now
Arisley's Avatar
Re: Best Synthetic Oil
Why? In the South we don't need it because of weather, and it aint' cost efficient.
Arisley is offline
post #3 of 35 (permalink) Old 02-01-2008, 03:34 AM
I use Rotella 5W40 an am very happy with it. My oil analysis reports come back great. The extra $30 per oil change does not bother me.
2000 F250 XLT PSD Crewcab, Longbed, 4x4, Auto, LS 3.73
jinco is offline
post #4 of 35 (permalink) Old 02-01-2008, 04:17 AM
<----Colin Banks
mattymx's Avatar
X2. My trucks run a lot smoother with it as well.
mattymx is offline
post #5 of 35 (permalink) Old 02-01-2008, 04:47 AM
I'm real happy with RP front to back.
TECH51 is offline
post #6 of 35 (permalink) Old 02-01-2008, 05:07 AM Thread Starter
I use Rotella also but i thought it would run better with synthetic and go longer
GotGMHP is offline
post #7 of 35 (permalink) Old 02-01-2008, 05:07 AM
Dieselgeek's Avatar
Syn Rotella 5w40 here...
2002 F350 Reg Cab,4x4,7.3,6Spd.
Dieselgeek is offline
post #8 of 35 (permalink) Old 02-01-2008, 05:10 AM Thread Starter
Also i am new to this site... how do you get your mods to post under your comment. haha
GotGMHP is offline
post #9 of 35 (permalink) Old 02-01-2008, 08:08 AM
Needs more hours per day
jtharvey's Avatar
I've been running Schaeffers 9000 for the last couple of years and am very pleased with it. UOA's showed a drop in wear metals (mainly iron and aluminum) compared to either the Rotella or Mobil I was running before. Truck seems to run better with the Schaeffers too.
For the info at the bottom to show up, you need to fill out your signature.
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #10 of 35 (permalink) Old 02-01-2008, 08:11 AM
Welcome!
I moved this to the fluids discussion forum for you.
I would recommend the Rotella synth to anyone. My truck loves it. I've been using DELO for the last while because of the cost, but last winter I ran Rotella synth and it was great.
To fill out your signature, go to "User CP" at the top left of the screen, then "edit signature:
gregrob is offline
