06 6.0 oil cooler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-02-2016, 04:11 PM Thread Starter
Davesyd's Avatar
06 6.0 oil cooler
So I recently bought a used 06 6.0 and the previous owner said that he has done the bigger oiler cool new turbo egr delete, basically everything but the head studs to bulletproof it, but recently Iv been monitoring my eot and ect and it seems there between 10-15 degrees apart, I'm not sure what the actual temp difference should be and, if it had a bigger oil cooler are there still chances for it to get clogged, I also have a coolant filter system from xdp installed, and what would be some sure signs of it becoming clogged?
Davesyd is offline
post #2 of 4 (permalink) Old 04-02-2016, 05:30 PM
Rivers1140's Avatar
Re: 06 6.0 oil cooler
There are some readings it should be no more than 15 degrees apart and I'm not sure about the bigger cooler. Image1459618055.960251.jpg
Rivers1140 is offline
post #3 of 4 (permalink) Old 04-02-2016, 08:24 PM
Administrator
Zmann's Avatar
any stock style cooler other than a OEM cooler will have a higher EOT temp right out of the box
the real worry is if the cooler that was used has the o ring type that will turn to go Like a Dorman kit
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 4 (permalink) Old 09-03-2016, 04:14 AM
From what I understand, if it is more than 15 degrees apart your wrench light on the dash will come on.
fwb35 is offline
