Motorcraft Announces Bag-in-a-Box Oil and Automatic Transmission Fluid - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-03-2016, 01:24 PM Thread Starter
Doors1Fan
doors1fan's Avatar
Say good-bye to one-quart packaging and hello to Motorcraft’s Bag-in-a-Box Oil and Automatic Transmission Fluid package. You’ll appreciate how it streamlines the entire process for enhanced productivity and cost efficiency. Here are some of the benefits:
The new Bag-in-a-Box Oil and ATF is priced less than quart pricing. It saves storage. It maximizes floor space. And each container has an easy-pour spout that drains quickly and efficiently — this can result in increased productivity and less waste for businesses that use it.
You can stock any combination of the following six oils and two automatic transmission fluids: 5W-20 and 5W-30 semisynthetic oil; 5W-20 and 5W-30 full synthetic oil; 10W-30 and 15W-40 diesel engine oil; and MERCON V and MERCON LV automatic transmission fluid. More products are in the works.
Each box provides the equivalent of 24 quarts or six gallons of product. Each rack is the equivalent of 192 quarts. Motorcraft has made the package as environmentally responsible as possible: 100% of each box is recyclable and the bag waste is less than one plastic quart bottle.
The rack is sturdy and durable and can hold eight products all in one convenient place. It’s about the same size as one 55-gallon drum and allows you to provide the right oils/fluids at the right time, minimizing inventory shrinkage. Drip pans prevent spillage and wasted product.
To get going, call your Motorcraft Distributor today and let your customers enjoy Motorcraft’s efficient Bag-in-a-Box Oil and Automatic Transmission Fluid package.
doors1fan is offline
post #2 of 10 (permalink) Old 03-03-2016, 01:30 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
Re: Motorcraft Announces Bag-in-a-Box Oil and Automatic Transmission Fluid
so it's got a little valve like a box-o-wine? i suppose one could put a piece of tubing on there & run the other end into the filler? or are these large bladders that require you to measure the oil volume before you fill? reason I ask, i could see myself hanging a 5qt bladder from the ceiling with a gravity feed tube going right in the crank case of my smaller vehicles, just like an IV lol
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #3 of 10 (permalink) Old 03-03-2016, 01:31 PM
Turd-250's Avatar
like this???
Turd-250 is offline
post #4 of 10 (permalink) Old 03-03-2016, 02:31 PM
Administrator
Zmann's Avatar
Interestig , i always hated throwing away all those empty jugs
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 10 (permalink) Old 03-03-2016, 05:33 PM
wackyman9's Avatar
I just burn everything once I'm finished an oil change, then I don't have milk jugs lined up around my shed.. oil burns, plastic Burns and I have no trash! Win win! Now, how do I re-install that smoke switch my dad took out.....
Sent from my SM-G925P using Tapatalk
-2008 Job #3 F250 CCSB 4x4
-Mishimoto Aluminum Radiator
-Peak Fleet Charge Purple Coolant
-SCT X4 Babysitter
-17" XD Addicts
-285 General Grabber AT2's
-Power Service White in the Tank
-Moog Tie Rods and Drag Arm
-Drilled and Slotted Rotors
-GearBoxZ DPF-R 4.0
-Flo-Pro DOC/DPF delete
-MPD CCV Kit
-Injen Evo CAI
wackyman9 is offline
post #6 of 10 (permalink) Old 03-03-2016, 05:57 PM
Turd-250's Avatar
i won't lie, it's handy to have some spare oil around to start up a wet pile of pushed timber! that's valid recycling, right?
Turd-250 is offline
post #7 of 10 (permalink) Old 03-03-2016, 05:59 PM
wackyman9's Avatar
Just for the record, I don't burn my used oil, that and the jugs get properly recycled. I wonder how much more convenient this will be vs the box store gallon jugs. I may give this one a shot.
-SCT X4 Babysitter
-17" XD Addicts
-GearBoxZ DPF-R 4.0
-MPD CCV Kit
-Injen Evo CAI
post #8 of 10 (permalink) Old 03-03-2016, 06:14 PM
Turd-250's Avatar
i'm sure the box will be easier for transport. no jugs sliding around the bed!
& seriously, synthetic 5/40 burns nearly as good as diesel does as for a brush pile starter!
Turd-250 is offline
post #9 of 10 (permalink) Old 03-03-2016, 06:56 PM Thread Starter
Doors1Fan
doors1fan's Avatar
Like this
http://ntvassets-a.akamaihd.net/0F3A...DD3D47FEBA.jpg
post #10 of 10 (permalink) Old 03-03-2016, 07:15 PM
Moderator
Sbluke55's Avatar
Almost 2 full oil changes in a box. Not too bad.
01 f-250, Standard
Sbluke55 is offline
