DRIVE TO REPAIR - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 12-30-2015, 11:32 PM Thread Starter
Exclamation DRIVE TO REPAIR
I have a 2001 F250 7.3 Diesel. Problem is most likely the water pump. All coolant is gone from the reservoir. I need to drive about 8 miles to have repaired. Will I have any problems?
BBELECTRIC is offline
post #2 of 6 (permalink) Old 12-30-2015, 11:39 PM
Administrator
Zmann's Avatar
Re: DRIVE TO REPAIR
flat bed tow 100 bucks? maybe free if you have towing insurance
driving with no coolant damage potential in the thousands
atleast fill the system with distilled and check it on the way
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 6 (permalink) Old 12-30-2015, 11:43 PM
jaybuller's Avatar
Re: DRIVE TO REPAIR
Pleeeeese do not drive with no coolant. Fill it up then drive it the leak can't be that bad!
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #4 of 6 (permalink) Old 12-31-2015, 01:04 AM
Luddite in Charge
Mr_Andy's Avatar
Re: DRIVE TO REPAIR
How long does it take to empty the reservoir? And this is a leak that's ending up on the ground, right? It would almost have to be, that's a lot of water to end up in the pan or out the tail pipe from the little bit you've described.
Sounds like you just discovered the problem and haven't had much in the way of diagnostics. Start out by filling the degas back up and running the truck. Whatever is wrong will call attention to and introduce itself in short order.
As for getting to the shop, there's no reason you'd be risking anything as long as you take precautions and rule out any other issue. If you're starting out cold you'll probably get about half those 8 miles covered before the thermostat opens and you start building up pressure anyway. Once that happens you'll immediately see any leaks. Just take along a gallon of distilled and top it off somewhere around the half way point. Obviously just don't let it run dry.
Mr_Andy is offline
post #5 of 6 (permalink) Old 01-03-2016, 10:11 PM
Re: DRIVE TO REPAIR
All good advice, but i will add this.. Do you have any idea how much antifreeze is in the system? If not, and or it takes more then just a gal of water to top the system off, consider adding anti freeze to the mix if need be.. Dont know where you are, or what the weather is, but the last thing you need is for the truck to be sitting around this time of year with weak or no anti freeze in the system, while waiting to be repaired.. Never know what you will run into with mechanic shops, and your looking at 10 dollars for a little piece of mind..
navistar45 is offline
post #6 of 6 (permalink) Old 01-03-2016, 10:29 PM
Strokin all day
Spence's Avatar
Re: DRIVE TO REPAIR
Yeah fill it back to cold fill range. If it takes more than a gallon use distilled. Let it run and if it's really bad you'll see coolant pissing out somewhere. That'll find your problem. If it isn't too bad a leak then drive it to the shop.
08 F350 Spartan tuned, egr delete, 5 in turbo back, no limit cai, ccv, cac pipe, bd 6.0 manifolds, bd up pipes, coolant filter.
3 vehicles in the scrap yard.
1 cummins sold to some boner next town over.
Spence is offline
