6.4 Fluids - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-10-2015, 12:11 PM Thread Starter
6.4 Fluids
I am sure this can be answered by someone who uses this site more, but is there a general 6.4 fluid thread anywhere? Oil, ATF, front/rear diff, coolant and transfer case. Didn't know if anyone had a list of recommendations all in the same place vs looking for hours to find each one. I am regular on my oil and fuel filters, but I am almost at 70,000 so I should at least do the tranny and maybe check the diffs. Possibly a coolant flush too.
If this thread doesn't exist I can sit down this weekend and try to find all the different fluids.
Also, how hard is it to do the transmission dipstick? Mine is crusty.
BillyBob427 is offline
post #2 of 2 (permalink) Old 04-10-2015, 02:46 PM
Administrator
Zmann's Avatar
Re: 6.4 Fluids
should all be in the manual
trans - Mercon LV
diff - on a tag on each dif 75-140 rear syn may need LS additive see if t shutters around corners
front is reg gear oil IDK weight off hand
crusty dipstick ??
tranny you either get a heated flush at ford or drop the pan do the filter and refill
then maybe run it and drain and refill again to get the clean to dirty ratio up
DTR's Donation page
RIP DTR Ron
Zmann is offline
