What is factory fluid in my 2006 f350 transfer case? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-17-2015, 09:32 PM Thread Starter
What is the factory fluid and how much does it hold? Thanks.
2016 F550 6.7 9' Dump work truck
2006 F350 6.0 Auto 95k miles. Sct programmer. 5 inch exhaust. Blue spring mod. Suspension mods and 35's.
1997 F350 7.3 Reg cab. Exhaust, coolant filter, front 2.25 PMF Rsk with Superduty Leafs.
gtmustang00 is offline
post #2 of 5 (permalink) Old 02-17-2015, 10:40 PM Thread Starter
Re: What is factory fluid in my 2006 f350 transfer case?
Esof btw. Not the manual stick. Not sure if it matters.
post #3 of 5 (permalink) Old 02-17-2015, 10:48 PM
mx185sw's Avatar
when i was chasing this on my truck.. Ford was confused.. it ended up being mercon SP from factory.. but ford has since released a specific transfer case fluild, that can be used going forward. 2 qts...
Motorcraft® Transmission Fluids – The Official Ford Parts Site | FordParts.com
Motorcraft® Transfer Case Fluid
Usage
•For use in transfer cases driving front axles on all-wheel-drive (AWD) and 4x4 vehicles
•Not for use in automatic transmissions, manual transmissions, power take off units (PTU), fluid couplers or AWD vehicles equipped with a transaxle
Sean
___________________________________________
2005 F250 Harley CC SB Banks IQ, 4" Exhaust, Banks Techi Cooler with High Ram, Cold Air Intake, Cat Delete,EGR Delete,Coolant Filter,Amsoil Oil Filter Bypass, PHP ECM Rollback, PHP FICM Tuner, WW2,Rancho 9000XL shocks. Firestone Air Springs w/Daystar Cradles. 224K
mx185sw is offline
post #4 of 5 (permalink) Old 02-17-2015, 10:51 PM
According to the manual, 2 quarts of Mercon ATF.
2006 F-250 6.0 Auto CC SB 4x4
charlez is offline
post #5 of 5 (permalink) Old 02-18-2015, 12:50 AM
mx185sw's Avatar
my bad... i looked back at my reciept and the notes on it.. dealer said mercon V can be used Mecon was original.. so i bought that. got home and bottle says not to put it in transfer cases (if i recall they didnt sell the older mercon any longer).. when i went back to dealer, and show them the bottle they were confused and didnt have a updated recommendation. I ended up purchasing the Mercon from autopart store.. then dug around the internet and found the Ford Transfer Case fluid was the recommended option now.
sorry for the mis info.. thx for corrrecting me .
Sean
mx185sw is offline
