atf? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 12-09-2014, 12:45 AM Thread Starter
atf?
what atf should I use in my zf6 it says to only use mercon not multi purpose mercon- merconv all the good fluid I can find now is the multi purpose mobil 1 syn.schaeffers, amsoil can I just use the multi purpose stuff it seams like most people on here are.
longbowhntr is offline
post #2 of 18 (permalink) Old 12-11-2014, 10:18 PM
International Coal Roller
jbwaldrop88's Avatar
Re: atf?
Yes, you can use a "multi purpose", just make sure it is Mercon III or Mercon V rated.
jbwaldrop88 is offline
post #3 of 18 (permalink) Old 12-13-2014, 12:14 AM Thread Starter
Re: atf?
Thanks I looked in the archives and I guess they dont make just plain mercon anymore I guess that all changed in 2006.On the amsoil sight it says I can use the multi purpose stuff or the torque drive for my truck.
post #4 of 18 (permalink) Old 12-18-2014, 12:42 AM
csp
Re: atf?
Valvoline has Mercon V, as well as the Mercon Maxgrade.
csp is offline
post #5 of 18 (permalink) Old 01-19-2015, 04:37 AM
Teecher45's Avatar
Re: atf?
If they don't make Just the plain Mercon anymore what should I be using in my 96 E4OD?
Teecher45 is offline
post #6 of 18 (permalink) Old 01-27-2015, 09:46 PM
csp
Re: atf?
Any current version of Mercon meets or exceeds the older versions.
csp is offline
post #7 of 18 (permalink) Old 01-29-2015, 03:32 PM
Teecher45's Avatar
Re: atf?
But when I've asked at the 3 stores they tell me they don't have any Mercon.
So, I hate to ask, but.
What ATF do I need to add to my 1996 7.3 AT? It's just a little low.
post #8 of 18 (permalink) Old 01-30-2015, 05:04 AM
JRF
Re: atf?
http://ts1.mm.bing.net/th?&id=HN.608...d=1.9&rs=0&p=0
This is what I use,
96 F250 XLT SCLB 4X4 E4OD
JRF is offline
post #9 of 18 (permalink) Old 01-31-2015, 04:16 AM
csp
Re: atf?
Are you aware that Mercon V is a designation of fluid, and not a brand?
Even Walmart carries Valvoline's Mercon V rated ATF, among others.
csp is offline
post #10 of 18 (permalink) Old 02-02-2015, 12:59 AM
Teecher45's Avatar
Re: atf?
Yes I am csp, but thanks.
I guess my question should be
"I have a 1996 7.3, the owners manual says I should use Mercon. Mercon is no longer produced, do I substitute Mercon V?"
Even if my transmission has Mercon in it (I have no idea what's in it) is Mercon V compatible, and I can just add it? I'm about a pint low.
