Diff fluid - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 11-29-2007, 05:18 AM Thread Starter
Oooo, White Lightning !
Dieselboy's Avatar
Diff fluid
It says use 75w140 for the rear....Does the royal purple have the limited slip additive in it ?....And the front is 75w90....Can you put the same weight (75w140) in both or should I just use the 75w90 for the front ?
And how do i tell if I have LS....When I first go the truck it would do 2 wheel stand stills....Now its a peg legger
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #2 of 15 (permalink) Old 11-29-2007, 07:35 AM
BUFF's Avatar
Re: Diff fluid
You dont need any additives with the royal purple, Use the recamended weight at both ends. There should be a tag on the diff cover that should tell you if its an ls or not.
06 F350 CC LB 4x4 with a few odds and ends
BUFF is offline
post #3 of 15 (permalink) Old 11-29-2007, 04:09 PM Thread Starter
Dieselboy's Avatar
Re: Diff fluid
What does the tag say....I think mine says 3L73 so the L is the Limited slip.....either way i think i fried the thing....Like i said when i first got it i did a brake stand and had 2 strips...Now Its only one....
Race truck
2002 F-350XL RC/LB
Unlimited 450/400s
TE 17* with Gen3
DI Headers
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
post #4 of 15 (permalink) Old 11-29-2007, 04:53 PM
OBS junkie
Cat_Rebel's Avatar
Re: Diff fluid
Just go with the Royal Purple & the correct weight for your truck. It'll be just fine. Go find a dirt road & brake torque your truck then take off & see if there are 1 or 2 ruts. Mine is a limited slip so I'll see the right side digs first then the left side kicks in & presto....2wd!
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #5 of 15 (permalink) Old 11-29-2007, 05:36 PM
BUFF's Avatar
Re: Diff fluid
Yup the L is for limited slip but the stock ones are junk the RP may help some it did with mine.
BUFF is offline
post #6 of 15 (permalink) Old 11-29-2007, 05:55 PM
fbilly420's Avatar
Re: Diff fluid
I thought I had an open diff until I changed to the royal purple. It made a huge improvement. I also switched to the 08 diff cover it looks alot cooler than the rusty stocker. And I can do two wheel peels all day long now.
Billy
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #7 of 15 (permalink) Old 11-29-2007, 06:35 PM Thread Starter
Dieselboy's Avatar
Re: Diff fluid
Billy
Im gonna get a Mag Hytec....I dont like the 08....looks to much like the nissan one
Race truck
2002 F-350XL RC/LB
Unlimited 450/400s
TE 17* with Gen3
DI Headers
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
post #8 of 15 (permalink) Old 11-29-2007, 09:00 PM
OBS junkie
Cat_Rebel's Avatar
Re: Diff fluid
Billy
So switching to RP really helps the LS lock up better? Might be worth it to do that to mine then.
RIP Will Iott
post #9 of 15 (permalink) Old 12-01-2007, 07:20 PM
dinnerbooter treasurer
genuineford's Avatar
Re: Diff fluid
Do what I did to my 08 cover. It took some time but way cheaper than a mag.
http://rides.webshots.com/photo/2001...AU?vhost=rides
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #10 of 15 (permalink) Old 12-01-2007, 11:20 PM
Re: Diff fluid
Probably not the fluid itself, but the amount (or lack of) LS additive already in the fluid.
gregrob is offline
