Fuel additives - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 07-12-2009, 01:37 AM Thread Starter
Fuel additives
Hello I just bought a 2000 cc lwb and wanted to know if I should run fuel additives or not? I have read some people run 2 stroke oil but wanted to know if I need to use any and if so what type.
renyren is offline
post #2 of 7 (permalink) Old 07-12-2009, 01:43 AM
Re: Fuel additives
I always run the power service you can get it at any parts store. they got a thread all about it in the fluids area on here good luck.
harleystroke_2005 is offline
post #3 of 7 (permalink) Old 07-12-2009, 02:27 AM
All done now
Arisley's Avatar
Re: Fuel additives
I run 2 stroke, about 1 oz per gallon. I just dump a quart is when I fill up. 38 gallon tank, I usually fill up around a 1/4 tank. Close enough for me.
Arisley is offline
post #4 of 7 (permalink) Old 07-12-2009, 02:31 AM
PSD
CNDiesel's Avatar
Re: Fuel additives
Thats what I use. TC3 or something.. Its 2 stroke outboard motor oil i run
1996 crew cab long box. 3.73s, auto 493/1135 stockish auto trans.
CNDiesel is offline
post #5 of 7 (permalink) Old 07-12-2009, 02:34 AM
All done now
Arisley's Avatar
Re: Fuel additives
Yep. Make sure it says ashless somewhere on it.
Arisley is offline
post #6 of 7 (permalink) Old 07-13-2009, 03:35 PM
Re: Fuel additives
Run it with a biodiesel blend of at least 5%. It will do better and cheaper than 2-stroke.
snakyjake is offline
post #7 of 7 (permalink) Old 07-15-2009, 04:34 AM
Freedom is not free
White Buffalo's Avatar
Re: Fuel additives
Here is a chart comparing the lubricity levels/effects of some diesel fuel additives. Although this is only comparing lubricity, it is a very important factor in ULSD fuels. Pick an additive that has good lubricity results, a water dispersant, cetane boost and a detergent. If in cold climates an anti-gelling agent.
The full report can be found at the pdf attachment at the bottom of this post.
Here is a link to some additional good info on diesel fuel additives.
Do diesel fuel additives really Work? How and Why ! - Truckinfo.net
hope the info helps......
White Buffalo is offline
