rear end fluid - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 07-10-2009, 02:03 PM Thread Starter
rear end fluid
What is the best fluid to put in a f350 that sees alot of towing and miles?
j350_05 is offline
post #2 of 11 (permalink) Old 07-12-2009, 05:54 PM
peterbilt'in
Rob02F350's Avatar
Re: rear end fluid
Mobil 1, 85-140... true synthetic oil. but a little bit on the $$ side..
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
post #3 of 11 (permalink) Old 07-13-2009, 03:29 AM
JHill's Avatar
Re: rear end fluid
Bigjake0524 and I split a 5Gal. bucket of Schaffer's 80/140 synthetic
cost was around a 100.00
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #4 of 11 (permalink) Old 07-15-2009, 04:46 AM
Freedom is not free
White Buffalo's Avatar
Re: rear end fluid
Me too...... Schaeffer's #167 75W-140
http://www.schaefferoil.com/datapdf/167.pdf
White Buffalo is offline
post #5 of 11 (permalink) Old 09-12-2009, 10:18 AM
Re: rear end fluid
Has anyone used Valvoline 75w140 full syn?
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
Torque37 is offline
post #6 of 11 (permalink) Old 09-12-2009, 02:13 PM
d-man
99coalroller's Avatar
Re: rear end fluid
Anyone used Amsoil severe gear?
2005 F350 CCLB King Ranch, 2.5"' Level, 35" Toyos on 08 20's, EGR Delete, 5" MBRP, Blue Spring, 6.4 Banjos, Rotella ELC
99coalroller is offline
post #7 of 11 (permalink) Old 09-12-2009, 09:12 PM
CtG
Re: rear end fluid
Definitely not a high torque application, but I used Valvoline full synthetic in my old Toyota Tercel 4wd wagon. I abused the hell out of that car, and it seemed to work great for the tranny and diffs.
Though, 74ft/lb's only relates so much to a Powerstroke... lol
Family Rides-
99.5 F250 PSD SC 4x4 SD: BTS, SS 4" Exh, 6637, 6-pos chip, 4" lift, Reg. Return, FFD 160CC Single's, GTP38R, Adrenaline, Fuel Bowl Delete- 410HP/828TQ Wheel
02 Excursion 4x4 PSD: 4" DP-back w/ Aero-Turbine, Larry's Black Box, BTS
CtG is offline
post #8 of 11 (permalink) Old 09-12-2009, 10:03 PM
PSN nerd
Re: rear end fluid
i have used both the amsoil and the shaeffers. There both great just the shaeffers is alot less money
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #9 of 11 (permalink) Old 09-14-2009, 03:39 AM
Re: rear end fluid
I found red line local. Just not sure what weight to use, 75w140 or 80w140?
Torque37 is offline
post #10 of 11 (permalink) Old 09-14-2009, 09:12 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Re: rear end fluid
I use all AMSIOL fluids,no complaints or worries.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
