Diesel Kleen - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 06-21-2009, 12:29 AM Thread Starter
kurtfromct's Avatar
Diesel Kleen
anybody use it and is it worth buying? i have a 97 PowerStroke with 139,000 miles and was wondering if this stuff is ok or if i should use another additive. also, which 1 do you use in the winter and summer? they have a white and silver bottle so i figure there is a difference.
1997 F-350 7.3 POWER STROKE. XLT, 4X4, BLACK, REG CAB, STRAIGHT PIPED, DIAMOND PLATE TOOL BOX AND BED RAILS
SOLD
kurtfromct is offline
post #2 of 27 (permalink) Old 06-21-2009, 12:37 AM
Re: Diesel Kleen
I Use the white bottle year round just as the bottle says to mix it i notice good cold weather starts.
harleystroke_2005 is offline
post #3 of 27 (permalink) Old 06-21-2009, 01:13 AM
brandon
bcangelo's Avatar
Re: Diesel Kleen
i use the stuff in the silver bottle. it is the summer blend, the white is for winter. It gives me about 8-10 percent mpg increase. Seems to give mine faster starts and a smoother idle. i also run it in 4 buses that i maintain for a local church group. Makes a big differance in those engines. one has the dt444e and the other three are 5.9 cummins. makes those buses start a lot better in the cold and make the run much smoother all year round imo.
2002 f-250 7.3 ex cab automatic, 4'' turbo back magnaflow exhaust. tonneau cover. SOLD
2011 f-250 6.7 Lariat fx4 with lots of extras!!Sold
2011 Screw Ecoboost 4x4 with ALL the options
Excuses are like butts, everybody got one and they all stink!
bcangelo is offline
post #4 of 27 (permalink) Old 06-21-2009, 02:02 AM
green member
roosterdiesel's Avatar
Re: Diesel Kleen
What injection pumps or parts does Diesel Kleen make?
I prefer Stanadyne Performance formula...every tank in my F250 and in my MX240 ag tractor...we buy it in 5 gallon jugs!
2001 F-250 handshaker
#54
Stealth HPOPs
Alliant ACs
Forged rods with other junk to make it work
Thanks to TDP, BDP, RDS, PHP and TDGrp
roosterdiesel is offline
post #5 of 27 (permalink) Old 06-21-2009, 07:11 AM
gracing's Avatar
Re: Diesel Kleen
Berryman used to make some good stuff but for reason they quit making it. I have been using the diesel clean and it seems to work fine.
gracing is offline
post #6 of 27 (permalink) Old 06-21-2009, 11:39 AM
Wondering what if
123rday68's Avatar
Re: Diesel Kleen
I've used both the white and gray bottles and for me running the white bottle year round works best. I noticed a gain of about a mile per gallon running it. I've talked with two over the road truck drivers that use it in their trucks too.
'07 F350 3" lvl, fndrs trmd, 37" M16's
Ultra lites ECT,EGT,EOT Oil and top fuel billet caps
banjo bolts drilled cautiously, ccv, zoodad mods Dieselsite coolant filter
SCT SF3 can tunes
Mike's Diesel Performance
KT Performance
DieselPowerProducts.com
Dieselsite
123rday68 is offline
post #7 of 27 (permalink) Old 06-22-2009, 01:08 AM
wildfingas @ the org
SuperDutyDon's Avatar
Re: Diesel Kleen
I use the white. Mostly because I dont feellike switching between the two and I also but it by the case and the other is its he same thing with the white having an anti gel additive put into it. The both have the ceatane boost and slick diesel lubricant.
Definately quicker starts in the winter though.
SuperDutyDon is offline
post #8 of 27 (permalink) Old 06-22-2009, 01:52 AM
Guest
Posts: n/a
Re: Diesel Kleen
I use the white bottle in the winter and the gray stuff in the summer. Works good for me. I also add 6oz of straight cetane (the ford stuff) and my 6.0 runs smooth and strong. The cetane level's in the fuel in my area are like 38. Not good. If I don't add anything it's like driving a different truck so I swear by the stuff..
post #9 of 27 (permalink) Old 07-31-2009, 08:10 AM
Big Mike
british columbia's Avatar
Re: Diesel Kleen
I seen a study on fuel additives lubricity and Opti- Lube XPD was the second best for lubricity on the chart cheers
2008 F350 Harley-Davidson ed. PSD
2.5 Inch Pro -Comp Front leveling Springs
british columbia is offline
post #10 of 27 (permalink) Old 08-03-2009, 04:48 PM
Re: Diesel Kleen
I use the silver bottle also. I noticed alittle bit better mileage.
jgos929 is offline
