Do I need TBN on my oil analysis? 8,275 miles 15 months, syn and bypass. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-26-2009, 12:37 AM Thread Starter
I run rotella syn 5/40 and it has been in there for 8,275 miles and 15 months. I have a sample ready to go off to blackstone. I have run this many miles but I have never had oil in there this long. I want to make sure I am ok to do this. What is the value of going with the TBN testing?
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #2 of 5 (permalink) Old 05-26-2009, 02:40 AM
All done now
Arisley's Avatar
Re: Do I need TBN on my oil analysis? 8,275 miles 15 months, syn and bypass.
I have run regular old Rotella dino oil that long.
Arisley is offline
post #3 of 5 (permalink) Old 05-26-2009, 02:50 AM
Doakster's Avatar
TBN is one of if not the single most important thing to test oil for. TBN stands for Total Base Number and is an indication of how much alkaline reserve is in the oil. Alkaline reserve gives the oil the ability to neutralize acidic conditions in the engine and prevent corrosion.
The base number will give you an indication of how much reserve is in the oil and ultimately how much life is left in the oil before it turns too acidic.
Blackstone will comment on the what you get for a base number and how far you can go with the oil.
I always get a TBN done and will continue to push the oil change longer mainly based on the TBN.
2003 F-350 4x4 SC 7.3, WOP QSSB Turbo, Isspro Gauges, MBRP 4 inch, AFE Stage II, , DP Tuned Stock, HI, 40t, 60t, 80t, 80e, 120R, 140ex, 6.0 Trans Cooler, 08 Tow Mirrors, 35in Kumho Mts
1993 International 4600 Dump, 7.3 IDI
Doakster is offline
post #4 of 5 (permalink) Old 05-26-2009, 02:53 AM
All done now
Arisley's Avatar
Good info, thanks Doakster.
Arisley is offline
post #5 of 5 (permalink) Old 05-26-2009, 10:35 PM
8k on Rotella T 15w40, my TBN was 7.2.
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
Torque37 is offline
